I can create a server, but nobody can join me
Frequent Asked Questions
Locked
Fortius Magical Man
Post by Fortius Magical Man » Thu Sep 20, 2007 8:49 am
There is a special document called Multiplayer Settings. It is available in 4 languages.
You can download it at (available from 22st of September)
http://www.tacx.com/service.php?fl=true ... %20manuals
There is a simple rule
1. To join servers, you need to open your Firewall settings (in some cases this is done automatically).
2. To create a server, you need to open your Firewall settings and you have to configure your router (port opening). The document explains how you can do this.
Keep in mind that everybody can create a server. It will also be visible in the server room (even if you did not change any settings to your router). If you did not open any settings other players will be rejected when they join your server (program will start loading, but will abort after a few seconds).
Locked
Return to “FAQ - Multiplayer”
