Neo 2 Cadence random values? (With 0.0.18)
fellrnr
Post by fellrnr » Sat Jan 12, 2019 5:24 pm
The cadence data from my Neo 2 seems random. It will vary wildly, with intermittent changes, which suggests it's only occasionally detecting the rotation.
I've tried with Ant+ (Golden Cheetah, Garmin) and with Bluetooth (Tacx iOS App) and all show the same (bad) values.
Any suggestions? Is there something I should attach to the crank arm, such as a magnet?
Re: Neo 2 Cadence random values? (With 0.0.18)
Post by Alex Masalovich » Sat Jan 12, 2019 8:06 pm
viewtopic.php?f=60&t=35429#p211025
0.0.18 - Is this the firmware number for Neo 2? You are the first who reported about it here on the forum.
pizzamann
Post by pizzamann » Sun Jan 13, 2019 11:48 am
i have the same problem!
i have tried to start it again, but it didn't work (with 0.0.18)
before i made the update, it worked without any problems
Post by Alex Masalovich » Sun Jan 13, 2019 11:54 am
Request a file with the previous firmware version in the support@tacx.com
Please publish this file if the support gives it to you.
fellrnr
Post by fellrnr » Sun Jan 13, 2019 2:13 pm
The latest firmware I have is 0.0.18. It seems like the issue is with how the Neo detects the crank arms. I'm guessing that different crank arm material, crank arm length, and the geometry of the bike (which changes the crank location relative to the Neo) all influence things.
I saw one post where someone had taped a metal bar to the crank arm to make it longer.
Post by Alex Masalovich » Sun Jan 13, 2019 5:12 pm
In the group of owners of Neo on Facebook the same topic is touched:
https://www.facebook.com/groups/TacxNeo ... 157643041/
NoShadowBike
Post by NoShadowBike » Mon Jan 14, 2019 8:37 pm
Here I have no Cadence at all :evil: This is the third time I have cadence problems with this expensive device.
So please build in a function to downgrade firmware as an other user already suggested.
@fellrnr
"saw one post where someone had taped a metal bar to the crank arm to make it longer"
This is one thing I already have done.
It works but on a more then 1000€ device :oops:
And now again problems... :roll:
Post by ms6073 » Mon Jan 14, 2019 9:57 pm
Suggestions like this are best emailed to support@tacx.com. While it may not be clear since Tacx hosts the forums, these are still user forums moderated by other users such as yourself and Tacx employees rarely visit!
Users browsing this forum: No registered users and 14 guests
