Neo 2 Cadence random values? (With 0.0.18)
fellrnr
Post by fellrnr » Sat Jan 12, 2019 5:24 pm
The cadence data from my Neo 2 seems random. It will vary wildly, with intermittent changes, which suggests it's only occasionally detecting the rotation.
I've tried with Ant+ (Golden Cheetah, Garmin) and with Bluetooth (Tacx iOS App) and all show the same (bad) values.
Any suggestions? Is there something I should attach to the crank arm, such as a magnet?
Re: Neo 2 Cadence random values? (With 0.0.18)
Post by Alex Masalovich » Sat Jan 12, 2019 8:06 pm
viewtopic.php?f=60&t=35429#p211025
0.0.18 - Is this the firmware number for Neo 2? You are the first who reported about it here on the forum.
pizzamann
Post by pizzamann » Sun Jan 13, 2019 11:48 am
i have the same problem!
i have tried to start it again, but it didn't work (with 0.0.18)
before i made the update, it worked without any problems
Post by Alex Masalovich » Sun Jan 13, 2019 11:54 am
Request a file with the previous firmware version in the support@tacx.com
Please publish this file if the support gives it to you.
fellrnr
Post by fellrnr » Sun Jan 13, 2019 2:13 pm
The latest firmware I have is 0.0.18. It seems like the issue is with how the Neo detects the crank arms. I'm guessing that different crank arm material, crank arm length, and the geometry of the bike (which changes the crank location relative to the Neo) all influence things.
I saw one post where someone had taped a metal bar to the crank arm to make it longer.
Post by Alex Masalovich » Sun Jan 13, 2019 5:12 pm
In the group of owners of Neo on Facebook the same topic is touched:
https://www.facebook.com/groups/TacxNeo ... 157643041/
NoShadowBike
Post by NoShadowBike » Mon Jan 14, 2019 8:37 pm
Here I have no Cadence at all :evil: This is the third time I have cadence problems with this expensive device.
So please build in a function to downgrade firmware as an other user already suggested.
@fellrnr
"saw one post where someone had taped a metal bar to the crank arm to make it longer"
This is one thing I already have done.
It works but on a more then 1000€ device :oops:
And now again problems... :roll:
Post by ms6073 » Mon Jan 14, 2019 9:57 pm
Suggestions like this are best emailed to support@tacx.com. While it may not be clear since Tacx hosts the forums, these are still user forums moderated by other users such as yourself and Tacx employees rarely visit!
NoShadowBike
Post by NoShadowBike » Thu Jan 17, 2019 5:58 pm
@fellrnr
I got a mail with the firmware package to downgrade. Now cadence is working again.
Post by Alex Masalovich » Thu Jan 17, 2019 9:08 pm
Can you share the firmware file with other users?
NoShadowBike
Post by NoShadowBike » Sat Jan 19, 2019 11:01 am
Sure but where can I put it :?:
Send you also pm.
Post by Alex Masalovich » Sat Jan 19, 2019 7:31 pm
To the collection of firmware for Neo2:
Version 0.0.15
Neo2_pack0.15.tacxfirmware
https://yadi.sk/d/sAn0b9HNlAKO6Q
From the description of the version: Road feel improved, Power measurement improved stability, Faster updates, Fan reduction of noise
Version 0.0.18
Neo2_pack0.18.tacxfirmware
https://yadi.sk/d/1pmSxsj3QatRRw
From the description of the version: BT cadence improvement Zwift
gadsdenjulie1951
Post by gadsdenjulie1951 » Sun Jan 27, 2019 11:37 am
I have just set up a Neo 2 with a new/clean Windows 10 machine running the Desktop App. As many have found, there was no cadence output or pedal stroke analysis, despite firmware upgrade to 0.0.18. Saw the earlier comment about extending the pedal/crank metal work to cover the invisible sensor behind the plastic panel and this has solved the problem! Excellent outcome but a bit disappointing about the Neo hardware design. The bike I am using is a old steel tube road bike with Campag 9-speed 170 mm cranks, so the 'Q factor' is quite high. Clearly, Tacx had longer/closer cranks in mind when they designed the kit???
Users browsing this forum: No registered users and 12 guests
