Tacx flow t2240
Moderators: mcorn, Tacx Moderator, malfukt, Tacx support, Nasz, alex
Tommystagnoli
Tacx flow t2240
Post by Tommystagnoli » Fri Dec 07, 2018 10:47 pm
Ciao sono nuovo il mio tacx flow mentre era in uso su Zwift purtroppo ha smesso di funzionare si è acceso il l’ex arancio vorrei sapere cosa posso fare xke l’app lo vede ma non aggiorna ne calibra ne riconosce la velocità vorrei sapere come fare x risolvere il problema grazie mille
Re: Tacx flow t2240
Post by Alex Masalovich » Sat Dec 08, 2018 7:27 pm
Provalo prima:
You did the firmware update, but now you have a Amber / Orange light on the brake unit? This means something went wrong with the update and you need to update again via these steps:
•Disable the trainer from the app
•Close all apps on the background
•Reinstall Tacx Utility app
•Take out the powercord for 60 minutes from your device
•Run the firmware update again
https://support.tacx.com/hc/en-us/artic ... ate-issues
Se non aiuta, quindi provare a tornare temporaneamente al firmware precedente:
It allows you to return the second part of the firmware to 0.3.4. This way is for use on a Windows-based computer with an ANT+ antenna:
1) download the Updater from here (no installation required):
https://yadi.sk/d/1J53YYde36LahA
unpack the archive.
Do not perform this step if you have installed the TTS4 and the Updater is already in the folder:
C:\Program Files (x86)\Tacx\TacxTrainersoftware4\updater
2) download the firmware 0.3.4 from here:
http://patches.tacxdata.com/data/files/ ... ke_034.bin
3) maybe, you will need the drivers from here:
http://tacxdata.com/files/support/TacxDrivers1230.zip
unpack the archive and run the file TacxDriversSetup.exe as administrator.
Do not perform this step if the Tacx drivers already installed.
4) place the trainer as close as possible to the ANT+ antenna,
restart the computer,
restart the trainer,
disconnect the Internet (otherwise the utility will report that there are no updates)
and run the file TacxUpdate.exe from the folder with the Updater.
Return to “Italiano”
