New Route Map added to the Tacx website
Discussion about the Tacx collection of Video for Tacx Training Software
Moderators: mcorn, Tacx Moderator, Tacx Video Production, malfukt, Tacx support, Nasz, Lunatix
Post by Tacx Video Production » Thu Dec 06, 2018 7:06 pm
https://tacx.com/product/tacx-films-tda/ scroll down to the bottom
For the 1st time for Tacx you can now see a map of just where you can ride with your TDA subscription, more rides are being added each month. In 2018 we filmed a number of amazing routes in Yorkshire, Catalonia, Bavaria & the Dolomites. We also are adding many of the best of the TTS4 collection.
To use the map zoom in on the icons & you can see where the routes go, sometimes they overlap if the start locations are the same, in that case just click the actual route & you will get the same pop-up info box for the route.
Image One of the routes on the way in this winter.
Loek
Re: New Route Map added to the Tacx website
Post by Loek » Sat Dec 08, 2018 11:32 am
Looks good! :). One thing I noticed: the maximum slope number is not correct, see the screenshot below. This is the case with all the routes it seems.
Post by Tacx Video Production » Sat Dec 08, 2018 11:41 am
Good find! I think the map does not have the same access to the ride data, as there is some data in there Im guessing its displaying the results of the heavily filtered data on the map which is designed to make it load really fast.
You can see inside TDA that based on the actual data the max grade is 25%... But it looks like the filter bars work still, you can find rides that have very steep grades or avoid them!
Loek
Post by Loek » Sat Dec 08, 2018 12:29 pm
Yes, correct. The filter bar still works okay. It's just the popup on the left that shows the wrong information. Hopefully this can be fixed in a future version of the website.
Loek
Post by Loek » Sat Dec 29, 2018 12:45 pm
Seems fixed now :).
Nasz
Post by Nasz » Thu Jan 31, 2019 5:36 am
Very nice too!
_______o
_____~\<,_
____(_)/ (_)
Train hard, ride easy
Return to “Tacx Real Life Video”
