no readings from Neo after connecting via blue tooth
windows 10 external blue tooth dongle. When I go to the device screen the Neo is there and I select all but there seems to be no transmission of data from the Neo. When I open a film and pedal nothing happens, it stays on the pedal to start or escape message.
When I look at the blue tooth settings in windows the Neo appears but under the driver details there is a warning message that a kernal was not migrated saying it was an ambiguous kernal and further actions are needed to install.
AMD Phenom X2 1055T 6 core
8G RAM
XFX Radeon HD 6950 1Gig video
60 Gig SSD harddrive for OS
1 Terabyte storage drive
Windows 7 64 bit
FORTIUS MOTORBRAKE
TTS 4.9.1
TTS3 3.12
8G RAM
Windows 7 64 bit
FORTIUS MOTORBRAKE
TTS 4.9.1
TTS3 3.12
- Tacx Video Production
- Contact:
Re: no readings from Neo after connecting via blue tooth
The top right there is a support button be sure to send the question via this. Tom is the guy you need if you can find him on the FB pages. But I think Tacx support will by now have a good idea of how to solve this one....Me Ive no idea what that error message means. Have you tried the dongle with any other software? I would try to google the error also as its Sunday.Gordonk wrote: ↑Sun Sep 16, 2018 6:20 pmwindows 10 external blue tooth dongle. When I go to the device screen the Neo is there and I select all but there seems to be no transmission of data from the Neo. When I open a film and pedal nothing happens, it stays on the pedal to start or escape message.
New Tacx Desktop Software https://tacx.com/product/tacx-software/
Strava Club http://bit.ly/TacxDesktopApp
FaceBook http://www.facebook.com/TacxRealLifeVideo
On occasions, I have had similar problems, but they are usually resolved by rebooting the BT transmitter and brake (unplugging, then replugging) and sometimes rebooting the PC as well. Be sure there are no other Bluetooth or ANT+ devices trying to access the brake or other sensors.
Thank you for the suggestions. the problem is resolved. I believe there was a conflict between my phone and the computer. Once I turned blue tooth off on my phone, then deleted the Neo blue tooth connection from the computer and rebooted every thing and repared the neo with the computer everything is now working.
Gordo
Gordo
8G RAM
Windows 7 64 bit
FORTIUS MOTORBRAKE
TTS 4.9.1
TTS3 3.12
8G RAM
Windows 7 64 bit
FORTIUS MOTORBRAKE
TTS 4.9.1
TTS3 3.12
Generally, if it is only a sensor (like heart rate or speed), multiple devices can access the sensor at the same time, including doing both BT and ANT+ at the same time. But if the device also receives signals and acts on them, you can get problems. Your NEO brake both sends and receives signals.Gordonk wrote: ↑Mon Sep 17, 2018 6:06 pmThank you for the suggestions. the problem is resolved. I believe there was a conflict between my phone and the computer. Once I turned blue tooth off on my phone, then deleted the Neo blue tooth connection from the computer and rebooted every thing and repared the neo with the computer everything is now working.
Gordo
Same thing is happening to me. I rebooted, unplugged and still doesnt want to connect. It shows the Tacx Neo and simulator. The simulator connects while the Neo doesnt. The bluetooth light on the Neo is illuminated. It will not connect in Rouvy either. I ordered a new BT4.0 Dongle as I'm using an old laptop circa 2013 running windows 10. Perhaps that may help? Is there something going on in the Neo itself?
On occasion I have TDA BT connection issues. To remedy I do the following:bigskypylot wrote: ↑Wed Oct 10, 2018 7:21 pmSame thing is happening to me. I rebooted, unplugged and still doesnt want to connect. It shows the Tacx Neo and simulator. The simulator connects while the Neo doesnt. The bluetooth light on the Neo is illuminated. It will not connect in Rouvy either. I ordered a new BT4.0 Dongle as I'm using an old laptop circa 2013 running windows 10. Perhaps that may help? Is there something going on in the Neo itself?
1. Close TDA
2. Unplug BT transmitter and then restart.
3. Unplug Brake and then restart.
4. Restart TDA
5. Go to Device page
6. Select select all for Neo (not simulator) - when Neo is both recognized and connected, NEO symbol will change from greyed to bright
7. Turn crank to confirm you are receiving NEO data
8. Confirm HR and any other sensors are also connected (going from grey to bright)
I'll try again but none 0f that worked when I tried it. ANT+ for TTS4 isn't working either or with Rouvy.for that matter.
This is beginning to sound like some other kind of problem. Have you tried any of the Tacx mobile apps. I would start with the utility app. I assume you are not trying to use ANT+ and BT transmitters at the same time on your computer.bigskypylot wrote: ↑Thu Oct 11, 2018 12:52 amANT+ for TTS4 isn't working either or with Rouvy.for that matter.
ANT+ dongle is unplugged. Tried to use TDA on my phone and does not find TACX NEO.
Tacx utility app tells me to contact tacx. I have Paul from Clever training trying to help me out. Going to try new bluetooth dongle on Friday when it arrives
Trying to attach screenshots but wont let me. I'm convinced it's a bad unit
It sure sounds like something bad happened to the trainer.
I would suggest contacting Tacx support https://support.tacx.com/hc/en-us
I just got it a month ago. It happened the first time I used the TDA lol
Really would not have anything to do with TDA. Just a coincidence. But it is very disappointing to have an expensive trainer fail quickly.bigskypylot wrote: ↑Thu Oct 11, 2018 10:09 pmI just got it a month ago. It happened the first time I used the TDA lol
Even if you are working with your dealer, it wouldn't hurt to contact Tacx Support at the link above or at support@tacx.com. In my experience, dealers often do not know much about a product although they may be the best place to get warranty service as the dealer can run interference for you.
I had to unplug and let sit several times but seems to be working for now
Electronic devices do not heal themselves with rest, although occasionally a defective device will work when cold and not after heating up. Bebooting really only requires unplugging for a few seconds. So, if this is now working while warm, I think there may be something else going on in your setup in terms of interference from other Bluetooth sources.bigskypylot wrote: ↑Sun Nov 04, 2018 5:36 pmI had to unplug and let sit several times but seems to be working for now
Does your laptop also have a built-in Bluetooth transmitter? If it does, be sure it is disabled so you are only using your external BT transmitter. You may have to go into your laptop's BIOS to disable a built-in Bluetooth transmitter.
