Taxc flow smart calibration
Questions and information about the Tacx.com website.
Vorpal
Post by Vorpal » Sat Jun 23, 2018 2:09 pm
Hi i have a problem calibrating the flow smart, when calibrating the trainer the sliding bar that tells you wether to tighten or loosen the the unit against the wheel is telling me i need to tighten. Problem is it is at its maximum adjustment and is very tight against the wheel. It has worked fibe until this week, this is the first calibration for nearly a month. The tyre is at 120 psi, it had the latest firmware. It has also been dropping bluetooth when it gets hot after about half an hour of use.
Re: Taxc flow smart calibration
Post by mcorn » Sat Jun 23, 2018 5:26 pm
Sounds like you could have a failing unit. You should contact support@tacx.com or your dealer. It has a 2 year warranty.
A better forum for this post is here:
viewforum.php?f=60
Return to “Tacx website”
