Firmware Update
Energyendurance
Firmware Update
Post by Energyendurance » Thu Feb 08, 2018 2:11 am
I’m running a studio with 6 genius smart trainers. I downloaded the latest firmware update and now as I pick up the cadence and get into heavier gears the wheel will start spinning at such a high speed that there is no longer a feeling of resistance even on the heaviest gear possible. Is it possible to reverse the firmware to when my trainers were working perfectly?
Re: Firmware Update
Post by Alex Masalovich » Thu Feb 08, 2018 7:19 pm
Use this useful utility:
Before you run the utility place the trainer as close as possible to the ANT+ antenna and make sure that the tyre is not attached to the brake’s roller. After the procedure is completed, turn off the resistance unit for 2 minutes.
