Firmware update on T2790 bushido for smart
Parky25
Post by Parky25 » Fri Jul 15, 2016 5:37 am
Can I update the firmware on Bushido for table ? Utility does not recognise the device and I only see bushido smart T2780 supported. I want to connect to Zwift but struggling.
Jollycity
Re: Firmware update on T2790 bushido for smart
Post by Jollycity » Sun Sep 11, 2016 2:21 pm
Hi. Did you figure this out? I have the same problem
clucking
Post by clucking » Sun Sep 11, 2016 4:27 pm
T2790 is not a Smart trainer and is therefore not ready for Zwift. Upgrading the firmware will not make it to a smart trainer and will not help you in any way.
Edit: According to Zwift it should be possible to use a bushido for tablet after a firmware update.
Shuttle XPC SX58H7 PRO
16 GB Ram
GeForce GTX 750 Ti 2GB eVGA
Win 10 64 bit
500 GB SSD
nhchl
Post by nhchl » Wed Sep 21, 2016 8:30 pm
I have the same problem. Bushido for Tablet isn't recognised by Tacx Utility App even though the following post states there is an update for the T2790 that will allow it to be controlled by Zwift.
https://support.zwift.com/hc/en-us/comm ... for-Tablet
mvriel
Post by mvriel » Fri Sep 23, 2016 9:27 am
It works. Period.
My setup does control my bushido T2790. Haven't used it for a while becaus of I ride outside at the moment. Will check again for you guys this weekend en come back here with the evidence.
Post by ms6073 » Fri Sep 23, 2016 3:41 pm
nhchl wrote:Bushido for Tablet isn't recognized by Tacx Utility App
You will need to connect your trainer to the Tacx Utility app to install the required firmware update to use Zwift. If your trainer is not seen/cannot connect to the Tacx Utility app, then you need to submit a ticket for the problem by sending an email to support@tacx.com.
neilpent
Post by neilpent » Tue Nov 27, 2018 8:41 pm
Hello!
I just purchased a new (heavily discounted) T2790, with the hopes of updating the firmware and then zwift! But no luck. The Tacx utility App doesn't recognize the T2790, and the online documentation only lists the utility app as supporting the T2780. Seems as though they pulled the support!
Oh well. the T2790 does communicate very well with the Tacx Training (and Cycling) App, and is controllable (changes resistance based on slope). I will just have to rely on my speed and cadence sensors to get onto zwift. It just won't be controllable by zwift. Not ideal, but at the price that I got my unit, i will not be complaining!
clucking
Post by clucking » Tue Nov 27, 2018 10:15 pm
Hello!
And you remember to cycle while trying to connect to the utility app?
16 GB Ram
Win 10 64 bit
500 GB SSD
