Flow Upgrade
smarkgee
Flow Upgrade
Post by smarkgee » Tue Nov 08, 2011 11:42 pm
I have recently been bought a tacx flow. nice unit.
what do i have to buy to do the following please?
1. some get my POWER DATA out of tacx and into sporttracks eg on a pc or with an ant+ stick?????
2. Get the ability to do simple lap/split - otherwise the average data shown is simply useless.
thanks
sc99cs
Re: Flow Upgrade
Post by sc99cs » Fri Feb 17, 2012 12:38 am
smarkgee wrote:I have recently been bought a tacx flow. nice unit.
thanks
I don't think that the Flow can output to a computer. My old 2007 model couldn't. You would have to buy a Tacx VR Upgrade Flow which is around £250. This would effectively give you a VR trainer and access to TTS3, RLV etc.
Steve Coburn
Telford, Shropshire. UK
AMD FX-4100 quad core 3.6 GHz; 8GB Corsair Vengeance 1600MHz DDR3 RAM
GTX 650 Ti Series Graphic Card 2GB DDR5 memory; SSD Boot drive
smarkgee
Post by smarkgee » Fri Feb 17, 2012 1:36 am
ty, yep i'd got the same info direct from tacx as well.
kingfisher
Post by kingfisher » Fri Feb 17, 2012 8:06 am
I did the Tacx Upgrade PC T1925.30 for Tacx Ergotrainers Cosmos + Flow
Which cost me 189 euros on an online shop. I believe I have seen it for a little less as well.
smarkgee
Re: Flow Upgrade
Post by smarkgee » Fri Jan 08, 2016 10:59 am
thanks
I'll answer my own question
a 1: this can be done using proxy power into sporttracks. you have to use wheel speed as a proxy for power and then a PC can re-broadcast the power back to your Garmin - it works.
a 2: you can't do it on the tacx device. once you have done the first thing with the proxy power your garmin can do it
