TTS4 General information
All information on TTS 4
Tacx support
Post by Tacx support » Wed Apr 09, 2014 8:48 am
Here is some additional information on TTS4 and some answers
1. TTS4 is Windows 7, Windows 8 compatible. Also for Windows vista, but vista is just not really stable
2 When installing TTS4 on windows 8, you might get an error message when installing the ANT drivers (.INF not found or cannot be installed) for the genius/Vortex/Bushido). Just press ok. Windows 8 will automatically search for the correct drivers when you plug in your ANT stick.
3. You can run the software on 1 pc at a time. When you want to swap the software to another pc, just start the software and go to HELP - SHOW LICENSE INFO - ADVANCED (blue line lower right side) - Transfer license. Now the license is deactivated on the Original pc and you can use the license on another other PC. If you system breaks down or you needed to change hardware on your pc, then send a mail to support@tacx.com with your license code. Your license code needs to be reopened
4. Video synchonisation. If your video is behind the official route, it means the video cannot synch correctly. Please go to Setup-settings then select video... In video select videoplayer 1
5. Trainers that will run with Tacx Trainer software 4
All, expect for one. The i-Magic T1902 full green interface will not run on TTS4.7 and combination of W7 en W8 64 Bit system. for this you need to buy the T1925 upgrade package
6. System specs. To see if Tacx Trainer works in your system, download the system specs checker: http://www.tacx.com/en/products/system-requirements
Re: TTS4 General information
Post by mcorn » Wed Apr 09, 2014 6:26 pm
However, the T1902 does run fine on TTS4 on a computer with 32-bit Windows 7.
F10-disel
Post by F10-disel » Sat Jun 28, 2014 5:08 pm
--> Do i need to do this individually for all of my liences (ie every RLV) or is it sufficient to do it once just for the TTS4 licence ?
Thanks in advance
Post by Lunatix » Thu Jul 03, 2014 2:12 pm
F10-disel wrote:3. You can run the software on 1 pc at a time. When you want to swap the software to another pc, just start the software and go to HELP - SHOW LICENSE INFO - ADVANCED (blue line lower right side) - Transfer license. Now the license is deactivated on the Original pc and you can use the license on another other PC. If you system breaks down or you needed to change hardware on your pc, then send a mail to support@tacx.com with your license code. Your license code needs to be reopened
Thanks in advance
Once, TTS4 is the license, the rest are modules who you activate with the license key
Thanks in advance
F10-disel
Post by F10-disel » Sun Jul 06, 2014 10:12 am
Thanks in advance
Thanks Lunatix
01gee
Post by 01gee » Wed Jan 07, 2015 11:59 pm
will the tts4 work on my fortius with i magic
Nasz
Post by Nasz » Thu Jan 08, 2015 4:21 am
01gee wrote:will the tts4 work on my fortius with i magic
Yes it will
_______o
_____~\<,_
____(_)/ (_)
Train hard, ride easy
reep
Post by reep » Fri Feb 13, 2015 8:35 pm
Me tts4 starts not up ,it's continuwed initialiseren !!
What to do ?
thanks !
Post by malfukt » Sun Feb 15, 2015 5:30 pm
usually initialising as syncronizing .tts files and videos, send log files to support@tacx.nl. they can be found C:\ProgramData\Tacx\TrainerSoftware\TTS4\logs. if you cannot see it, you will need to go to files options and select "show hidden files and folders"
Post by Lunatix » Mon Feb 16, 2015 10:36 am
reep wrote:Me tts4 starts not up ,it's continuwed initialiseren !!
What to do ?
thanks !
If you want to get assistance on the forum. Make a different topic and paste the error in the topic and we might be able to already assist you. Or just e-mail Tacx support at support@tacx.com : This can be done in Dutch/English/French/German
nn3gee
Post by nn3gee » Sun Dec 13, 2015 5:48 pm
Is the plan that with the move to FEC ANT+ connection, TTS4 can be used with ANY FEC ANT+ trainer? Not just Tacx ones?
Post by Lunatix » Wed Dec 16, 2015 12:26 am
nn3gee wrote:Is the plan that with the move to FEC ANT+ connection, TTS4 can be used with ANY FEC ANT+ trainer? Not just Tacx ones?
This is already possible in TTs4 and TCA.
LeeRobbo
Post by LeeRobbo » Mon Jan 04, 2016 9:17 pm
Hi guys
I bought TTS4 basic and then bought the expert upgrade a little later.
Can I treat these as separate software and use them on two PC's?
Cheers
Genius Smart
Xeon X5670 2.93GHz / 24GB DDR3 1333 Ram
NVidia GeForce GTX 970 / 120 + 250 840 pro SSD
Win10 64 / TTS4 / 42" LEDTV
Bushido T1980 (sold)
i-Magic (sold)
Post by ms6073 » Mon Jan 04, 2016 10:54 pm
LeeRobbo wrote:Can I treat these as separate software and use them on two PC's?
I am thinking this wont work as the Advanced version installer performs a license check prior to install then simply enables modules that were not included for the basic license. Of course this may be way off base and my suggestion would be to download the full TTS 4.16 dvd installer (its a big download), which you could then install on separate computers. When you start TTS, use the basic license on the first computer and the advanced license on the other.
LeeRobbo
Post by LeeRobbo » Tue Jan 05, 2016 12:53 am
Thanks for the reply and the link :)
I think your idea may just be worth a try, why not, I'll see what happens.
Cheers
Genius Smart
i-Magic (sold)
cmat
Post by cmat » Tue Jan 05, 2016 12:54 am
Tacx support wrote:Here is some additional information on TTS4 and some answers
Will it be possible to install TTS4 on a pc with too low specs? Just to do check it out before I upgrade my pc.
clucking
Post by clucking » Tue Jan 05, 2016 11:30 pm
cmat wrote: Will it be possible to install TTS4 on a pc with too low specs? Just to do check it out before I upgrade my pc.
Yes, if you buy the software. It is possible then to transfer the license from one PC to another.
Shuttle XPC SX58H7 PRO
16 GB Ram
GeForce GTX 750 Ti 2GB eVGA
Win 10 64 bit
500 GB SSD
workingbirds
Post by workingbirds » Sat Mar 05, 2016 5:06 pm
My Vortex trainer arrived today, I have it assembled and the bike mounted, all plugged and ready to ride. I have downloaded Tacx Trainer app to my iPhone, opened the app for the first time, and see a "Sign Up Welcome to Tacx" screen. Apparently I must sign up either through Facebook or Google+; the Google+ button tells me that Tacx Cloud would like to access all sorts of information about me that I see no need to share. When I click "Deny" I am told "our server is down, try again later." Is the server truly down, or will I always get this message if I don't "Allow" access to my circle of friends? Can't I just use the Trainer app and the trainer machine privately, without the cloud?
Post by ms6073 » Sat Mar 05, 2016 8:33 pm
Yes, there should also be an option to train offline where you will be prompted to create a new user and enter basic information.
