Help. Windows 7 upgrade
mtcross
Post by mtcross » Mon Jan 14, 2013 7:46 pm
Hello. I have a fortius unit with tts 3.12. It was running ok but I want to upgrade to TTS 4.5 so I upgraded my machine from Vista to Windows 7. Now tts loads but there are no drivers for the unit. I tried using drivers from tts 2 and tts 1 but cannot get them to install.Ideas? I can clean install but will likely have problems with my licenses. :(
Post by malfukt » Mon Jan 14, 2013 9:04 pm
Reinstall drivers from the disc, go into device manager & check driver under `Jungo` there should be `windriver` there, you can update driver & point to TTS disc
Make sure usb is disconnected from PC
mtcross
Thanks but
Post by mtcross » Tue Jan 15, 2013 2:58 pm
Well, that didn't work. I found an old RLV Pyrennes disc, with fortius drivers. Windows 7 tries to update the driver, but then says the driver is p to date. When I go to TTS 3.12, I still only have a check box next to the HR monitor. The steering frame, power unit, and trainer are all red X's. IDeas?
Post by malfukt » Tue Jan 15, 2013 7:44 pm
In device manager, uninstall//remove the drivr, reboot PC re-install driver, then plug in USB
mtcross
thanks
Post by mtcross » Tue Jan 15, 2013 8:54 pm
Should've known -uninstall first. Thanks
Todd
