Bushido T1980 electro unit
Dickywhizz
Post by Dickywhizz » Thu Aug 09, 2018 2:10 am
Hey Guys,
I am chasing some information about the Bushido T1980 (although I think it will be the same on other Bushido models).
I think my unit has been dropped during transportation and a couple of components on the electro unit PCB have dislodged.
One of them was the 220uH power inductor and the other one was a smaller component which I think should be a resistor.
The inductor was found inside the unit but unfortunately the resistor(?) must have fallen out.
I tried to attached a picture of my circuit board with the missing components highlighted but unfortunately the site would not let me!
So I will try to describe!
The resistor is immediately to the right of the large inductor (with 221 on top), and is the top component in a set of 4.
The bottom two are larger beige capacitors, then the next is a smaller beige capacitor and then I have a gap.
I think the next component should be my resistor but I do not know what value?
I think the inductor is a Wurth Electronik 744770222 but not certain.
Can anyone please tell me what the parts should be or even post a good quality picture of their board?
Or even just post what numbers/letters are printed on top of the resistor?
Thanks in advance
Dicky
Re: Bushido T1980 electro unit
Post by Alex Masalovich » Thu Aug 09, 2018 11:02 am
The forum allows you to embed images from external sites using the img tag, for example:
Code: Select all
[img]https://all4bikes.be/shop/images/tacx/t2784.11b.jpg[/img]
Place your picture on any photohosting.
Post by mcorn » Thu Aug 09, 2018 4:45 pm
If I were to place a bet, physical damage to your board sufficient to break off some surface components will have caused other problems as well. I would start looking for another unit. In my opinion, the Bushido was not a great brake, although I am sure others will disagree.
I do have a couple of so-so pictures of my Bushido T1980 board, so if you send me a private message with your email address, I can send them to you. They may not be much help.
P.S. I just looked more carefully at my pictures and I do not see the 221 inductor, so they may have changed boards somewhere along the way.
Dickywhizz
Post by Dickywhizz » Fri Aug 10, 2018 12:56 am
Thanks for the responses guys.
You may be right regarding the additional damage, time will tell but I'll give it a go first.
Fortunately, after a second begging email to Tacx they have sent me a picture of the section of the board in question.
The resistor I'm chasing is a 1 ohm device. So will keep fingers crossed.
Cheers for now :D
Users browsing this forum: No registered users and 18 guests
