reset and reload firmware
goixiz@gmail.com
Post by goixiz@gmail.com » Wed Feb 14, 2018 4:37 am
I want to reset my Tacx Bushido so there are no devices connected to it and enable FE-C on zwift and reinstall the latest firmware
What cani do to reload FW and reset the bushido
Re: reset and reload firmware
Post by ms6073 » Wed Feb 14, 2018 3:11 pm
Bushido Smart or legacy Bushido? From the range of questions, it sounds as if you might have a older legacy Tacx T1980 Bushido which is not ANT+ FE-C compatible. As for connections, regardless of which type of Bushido, although the trainer can be connected to apps such as TTS, no devices actually 'connects' to the Bushido.
goixiz@gmail.com
Post by goixiz@gmail.com » Thu Feb 22, 2018 12:19 am
I have the bushido smart
When running standard Zwift - the trainer does change resistance when the terrain/elevation changes - it also reads the power and cadence (although i have a separate cadencewith my bike setup)
With the above i believe the issue is that the FE-C option is not released from the TACX and thus not allowing zwift to select it during setup and hence no ERG mode
Post by ms6073 » Thu Feb 22, 2018 4:31 am
Nope. Unlike Bluetooth LE, ANT+ FE-C is connection agnostic so as long as only one app at a time is trying to control the trainer, it should not be an issue.
Users browsing this forum: No registered users and 11 guests
