Gearing problems
cycling2011
Gearing problems
Post by cycling2011 » Thu Oct 06, 2016 8:25 pm
I have a Shimano 105 cassette on the Neo.With the provided spacer there was play on the cassette so I added a spacer to stop this.I now find I cannot get in the smallest socket of the cassette from large or small chainring.Also the gears do not work smoothly.I have tried my 3 bikes and even taken bike/Neo to LBS but problem is stil there.
i7-8700k,6 Cores,3.7GHZ,4.7GHz Turbo.
Asus Strix Z390-F Mother Board.
16GB Ram 3000 MHz.
MSI Nvidia GTX 1080 Ti 11GB.
250 GB SSD.
4TB,2TB,2TB WD HDs Storage.
Neo 2
TDA Beta.TTA Beta.
Re: Gearing problems
Post by ms6073 » Thu Oct 06, 2016 8:58 pm
By adding spacers behind the cassette of the Neo, the freehub spacing has been altered, requiring derailleur high/low screw adjustments. If you took both the bike and the Neo the your LBS, the mechanic should have been able to make the required adjustments, but since will require an additional spacers on the freehub of the bike wheel otherwise the bike will suffer the same issue as the Neo once you are riding back out on the road.
Blueberry
Post by Blueberry » Fri Oct 07, 2016 5:48 pm
maybe try to put a spacer not in the back of the cassette, put it in the front just behind the lockring
cycling2011
Post by cycling2011 » Fri Oct 07, 2016 6:42 pm
I have been altering the high and low screws on the derailed.I can now go into the smaller socket of cassette.Still not 100% smooth and skipping some gears and clicking on others.Any suggestions on how to fine tune it to get it running smooth .
16GB Ram 3000 MHz.
250 GB SSD.
Neo 2
TDA Beta.TTA Beta.
Post by ms6073 » Fri Oct 07, 2016 9:48 pm
cycling2011 wrote:Still not 100% smooth and skipping some gears and clicking on others.Any suggestions on how to fine tune it to get it running smooth .
Did you install a brand new cassette on the trainer? I ask because the symptom described sounds like what happens when you have a worn chain paired with a brand new cassette.
cycling2011
Post by cycling2011 » Fri Oct 07, 2016 10:23 pm
New Cassette and new chain.Starting to get better with fine tuning low/high screw and barrel adjuster.Being looking at U-Tube videos on fine tuning Shimino 105 gears.
16GB Ram 3000 MHz.
250 GB SSD.
Neo 2
TDA Beta.TTA Beta.
cycling2011
Post by cycling2011 » Tue Oct 11, 2016 7:54 pm
My Neo I have had about 2 weeks has never run smoothly on the cassette gears.
I have had 3 bikes on this Neo and it is not staying on the middle gears,skipping gears and never felt right.
All these bikes work perfectly on the back wheel the Neo replaced.
I took Bike/Neo to well known bike shop in my area.
He spent 3 hours changing cassettes,deraillers and checking everything that could be faulty with bike and cassette on Neo.
He concluded that the bike works perfectly through the gears with the normal wheel and that the Neo has a fault
Has this problem been reported in the past?
16GB Ram 3000 MHz.
250 GB SSD.
Neo 2
TDA Beta.TTA Beta.
IronSteve226
Post by IronSteve226 » Fri Oct 14, 2016 10:11 pm
I had the same problem - after hours of colourful language, figured out that the Shimano cassette can go on the free hub in two different ways and when all the gears don't line up (i.e. not placed on the free hub in the same way) you get what you explained above.
cycling2011
Post by cycling2011 » Fri Oct 14, 2016 10:43 pm
Getting the cassette on took ages.What do you mean by 2 different ways? Tacx say the ECDO might be damaged.I have sent it back for replacement but do not want the same thing happening again.Thinking of going up to Ultegra with this one.
16GB Ram 3000 MHz.
250 GB SSD.
Neo 2
TDA Beta.TTA Beta.
Mr_Tea
Post by Mr_Tea » Sun Mar 19, 2017 10:01 am
Do you ever get this fixed? I have the same issue.
Also what is meant by fitting the Shimano casette in 2 different ways??
Ta for help
cycling2011
Post by cycling2011 » Sun Mar 19, 2017 11:23 am
Replaced Turbo bike from 2011 Specialized Allez to 2017 Giant Contend SL.
Seems like some older bikes do not work through the gears smoothly no matter what you do.
Trainer is now silent and works perfectly through all gears :D
16GB Ram 3000 MHz.
250 GB SSD.
Neo 2
TDA Beta.TTA Beta.
Mr_Tea
Post by Mr_Tea » Tue Mar 21, 2017 4:15 pm
Cheers, for prompt reply. didn't fancy buying a bike. But today, no clicking! Problem gone, and never changed a thing. Very weird.
cycling2011
Post by cycling2011 » Tue Mar 21, 2017 8:14 pm
Reckon it was my Neo,s way of asking for a new bike.
Whatever my Neo wants it gets. :wink:
16GB Ram 3000 MHz.
250 GB SSD.
Neo 2
TDA Beta.TTA Beta.
Sanity93
Post by Sanity93 » Wed Jun 13, 2018 1:31 pm
quite an old post but it's first on google so i want to help you to solve it. I had the same fckn Problem and went crazy...
Solution Steps:
1 Check if the cassette is correct on the tacx hub (you can mount the cassette in 2 ways if it's a shimano one)
2. Check your cassette - if you use 11/28 on your Roadwheel and 12/25 (yes it is 12 not 11 i never realized that) you have to use the second Lockring for your tacx neo.. there a one for 11T and 12T cassette - check the cassettemanual from tacx
3. maybe its a new chain on a worn cassette.
For me it was the second step: I never realised that shimano selling 12-25 not 11-25. I also didnt know that there're 2 Lockrings for your cassette on the tacx.
If you take the wrong Lockring it will fit with no issues at all but your gears are jumping all over the place no matter how your indexing is.
Hope that helps! Cheers!
Unhookt
Post by Unhookt » Fri Oct 05, 2018 2:15 am
I just received a Neo 2800 with pre installed 8-11 speed Shimano-compatible cassette and my chain is similarly jumping all over the place. I don't know how to address this issue and can't imagine the solution should be recalibrating the rear derailleur - defeats the purpose of an easy-on/off rear wheel trainer if I can't just pop my wheel back on when I want to ride real roads.
The bike is a 2006 Litespeed Firenze with 2016 Dura Ace component group and C-7900 10-speed Dura Ace rear cassette.
Please advise - I don't want to have to return this thing but I refuse to recalibrate my shifters each time I attach the bike to the trainer on a rainy day.
Post by Alex Masalovich » Fri Oct 05, 2018 11:21 am
If you do not want to tune your rear derailleur, tune your cassette with spacers.
Post by ms6073 » Fri Oct 05, 2018 4:48 pm
You are mixing apples and oranges. If the trainer came with an 11-speed cassette already installed, but your bike is equipped with a 10-speed Dura-Ace 7900 drive train, then you have already identified the issue. No amount of adjustment is going to make a bike with a 10-speed drive train shift smoothly on a Tacx Neo with an 11-speed Shimano cassette. To resolve the issue you either going to need to install a 10-speed compatible cassette and spacer, alternately, purchase a newer bike with an 11-speed drive train.
Unhookt
Post by Unhookt » Fri Oct 05, 2018 4:53 pm
The cassette sold with the trainer indicates that it is compatible with 8-11 speed Shimano drivetrains. As such, I was led to believe that my 10 speed set up ("10" clearly being between "8" and "11") would be compatible.
I see mention of spacers on this forum and in the (sparse) set up manual that comes with the trainer, but no guidance as to what the effect or application of the spacers should be. Can someone help with this?
Post by mcorn » Fri Oct 05, 2018 6:30 pm
So, I am assuming that you were provided a 10 speed Shimano cassette to go with your new Neo. Is that correct? You can't mix an 11 speed cassette with 10 speed shifters.
The NEO is a little like putting a different wheel on your bike. Unless you have 2 identical wheels, changing wheels often requires readjusting the derailleur. As Alex says, if you go to your local bike shop or an bike parts supplier, you can obtain spacers that you could use to adjust the inboard-outboard position of the cassette. A thicker spacer next to the Neo moves the cassette outboard and a thinner one moves it inboard. If you got this just right, you might be able to make the Neo and your wheel interchangeable without having to adjust your derailleur.
Here is an example of 1mm spacers. They come in different thicknesses, but you can use more than 1mm to get the cassette positioned to where you need it. If 1mm is too big, you might need a thinner one.
https://wheelsmfg.com/products/rear-dri ... w-1-0.html
Post by Alex Masalovich » Fri Oct 05, 2018 7:48 pm
:shock: And at first I did not understand the whole absurdity of this phrase. I suggested that it is not the cassette itself that is meant, but a body that is compatible with standard Shimano/SRAM (8 to 11 speed) cassette.
You probably mean this:
This inscription is not about the cassette, but about the body:
Users browsing this forum: No registered users and 21 guests
