Calibration on a fixed gear track bike
Goyt
Post by Goyt » Sat Feb 06, 2016 1:01 pm
I'm wondering what the correct method to calibrate my Tacx Bushido Smart when using it with a fixed gear bicycle?
The calibration process says to 'stop pedalling' but that isn't really possible on a fixed gear, what is the recommended procedure? Just unclip from the pedals and let it spin or just let your legs spin down with the pedals?
keiken
Re: Calibration on a fixed gear track bike
Post by keiken » Fri Sep 14, 2018 12:01 pm
Hello, have you find a solution about it? im in the same situation with tacx vortex
Post by ms6073 » Fri Sep 14, 2018 5:19 pm
No experience with fixies, but the update routine is uses the time required to for the rear wheel to spin down to zero as part of the calibration process, so assuming you are using clipless style pedals and not straps, my suggestion is to unclip your shoes from the pedals and move your legs out of harms way so that the rear wheel will spin down similar to how it would if you were using a geared bike.
Users browsing this forum: No registered users and 15 guests
