Testers wanted for Ant+ wireless power meter firmware update
Post by ms6073 » Fri Jul 20, 2012 2:11 pm
It's official, TTS news update indicates Bushido firmware 5.13 is now available for update.
Dedgi
Post by Dedgi » Fri Jul 20, 2012 4:10 pm
ms6073 wrote:It's official, TTS news update indicates Bushido firmware 5.13 is now available for update.
I will dowload it and try it later in the Fall. In the meantime, if anyone tries it, it would be nice to get the feedback.
René
Post by ms6073 » Fri Jul 20, 2012 7:19 pm
I installed it shortly after posting and then did a short 30-minute training in stand alone mode. Good news is the intermittent Pause popup that the BETA test group observed with 5.10 have been corrected and once paired and calibrated with my SRM, the motorbrake seemed pretty stable with a few intermittent high/low surges in resistance.
Problem I found was that in stand alone mode, if I exited a trainng program before completion and immediately started another, after the countdown, the motorbrake immediately started setting resistance such that power values on Bushido were 15-30 watts higher lower than those from my SRM as displayed on a Garmin Edge 500. Stopping the program and then going re running the Bushido Power Meter calibration (Settings -> External Sensors -> Power Meter -> Calibration) appeared to resolve the issue but as soon as I stopped the program before completion and started another, Bushido again was setting motorbrake resistance levels for much higher power levels than indicated on the handlebar controller.
dougleybourne
Post by dougleybourne » Sun Jul 22, 2012 6:56 am
I have just installed 5.13.
No problems except that when I started a RLV there was a "pinging' sound from the brake. This lasted for about 40 seconds and then died away.
After about 28 minutes there was a "bong" "bong" noise from the brake, I eased off my cadence a bit and the "bong" stopped. After 33 minutes it started again and got more and more persistant and louder. I aborted the ride.
I checked the brake , it felt quite cool.
Nothing like this has happened before, I have used the Bushido since August 2009.
Any ideas anyone? I'll try again tomorrow and will report if anything untoward happens.
Tisztul_A_Visztula
Post by Tisztul_A_Visztula » Wed Jul 25, 2012 9:19 pm
Last edited by Tisztul_A_Visztula on Fri Feb 22, 2013 1:29 pm, edited 1 time in total.
Dedgi
Post by Dedgi » Sun Aug 12, 2012 3:30 pm
I finally tested the new Bushido software. It works OK, but there are a few problems that are still there. There are the occasional instabilities where the resistance increases for no reason. Also at the end of the workout, the box that asks whether or not to save the session does not detect the brake. Fortunately there are posts that indicate how to work around this problem. I wonder why Tacx has not solved those problems. Unfortunately, with the instability of resistance, we do not fully benefit from this improvement.
Post by ms6073 » Thu Aug 16, 2012 7:02 pm
I think the instabilities in motorbrake resistance are a combination of very minor ANT+ signal interference as well as the Bushido exagerating the naturaly stochastic nature of power measurement/output.
See my post in the Ride not letting me save thread.
Dedgi
Post by Dedgi » Thu Aug 16, 2012 9:43 pm
I know it is probably hard for you to explain your point, I am not sure I fully understand your post. Instead on unplugging and replugging the dongle, did you solve the problem by simply repointing the dongle in a different direction?
Post by ms6073 » Thu Aug 16, 2012 10:23 pm
I won't know whether or not reposition the Ant+ USB makes any difference until after test this with tomorrows training.
Tisztul_A_Visztula
Post by Tisztul_A_Visztula » Thu Aug 16, 2012 10:41 pm
Last edited by Tisztul_A_Visztula on Fri Feb 22, 2013 1:16 pm, edited 1 time in total.
Post by ms6073 » Fri Aug 17, 2012 8:57 pm
Now have to agree that this looks like a software defect possibly with common/shared code between TTS 3/4. With the ANT+ USB stick positioned ~3ccm from and pointed directly at the underside of the Bushido handlebar controller, I did percieve a very slight improvement in motorbrake response during my training session but that did nothing to resolve the issue with not being able to save the ride after completing the training program. So has anyone actually reported to Tacx or have we just posted to the forums about the issue?
Dedgi
Post by Dedgi » Sat Aug 18, 2012 1:52 am
I am not aware of anyone reporting the problem to Tacx.
Tisztul_A_Visztula
Post by Tisztul_A_Visztula » Sat Aug 18, 2012 9:35 am
Tisztul_A_Visztula
Post by Tisztul_A_Visztula » Mon Aug 20, 2012 7:43 pm
tretiak
Post by tretiak » Tue Nov 13, 2012 9:46 am
Hello,
I have attached Quarq S975 with TTS 3.12. The main computer has software 5.13.
When I run the RLV, Catalyst, I get occasional pause message, brakes react correctly and reduces drag.
But very often I notice while studying the graph cycling or in Analyzer that power, heart rate and speed dive to zero for a second and then returns to the current (correct) value. The brake does not respond to this luckily. But the problem is that the averages (power, heart rate and speed) is wrong in the Analyzer.
When disconnecting Quarq then it's OK. Generally, I think the brakes react properly as road profile.
regards
Kevinm
Post by Kevinm » Tue Nov 13, 2012 3:07 pm
This is a known and persistent bug and appears to be due to a temporary lack of acquisition by TTS of the ANT+ values.
Report it to Tacx and hopefully it will be corrected as was the false overheating warning in the current TTS release.
i7 (Quad cores 2.50 GHz)
8GB RAM
NVIDIA Quadro 3000M 2GB
Windows 7 Pro 64-bit
Extreme (Core 2 2.8 GHz)
4GB Ram
Nvidia FX Quadro FX3600 512MB
Windows 7 32-bit
Genius, Bushido (+flywheel), Powertap SL+, Blacktrack
TTS 3.11 & TTS 4.3
martin_vortex
Post by martin_vortex » Tue Nov 13, 2012 5:03 pm
Kevinm: This is a known and persistent bug and appears to be due to a temporary lack of acquisition by TTS of the ANT+ values.
Thanks Kevin, (additional) info much appreciated!
Albert Einstein
On the Theory of Relativity.
rikicarra
Post by rikicarra » Tue Nov 13, 2012 11:11 pm
I have exactly the same configuration, Quarq S975, Bushido with firmware 5.13, TTS 3.12. I have tried multiple times to do RLV, RLT and VR with the Quarq connected to the Bushido head unit, but the connection is erratic and I was not able to finish trainings. I have now disconnected the Quarq from the head unit, I am using the power calculated by the Bushido and not the one measured by the Quarq, everything is now back to normal. And by the way I have measured the difference between the Bushido brake and the Quarq, if you do the setup correctly it is a negligible 1.5%.
Neo Smart - TTS4.22.5
W10 64bit - 4GB RAM - Asus GTX 560 Ti 2GB
LG 50" FullHD
Kevinm
Post by Kevinm » Tue Nov 13, 2012 11:59 pm
Martin that statement is only my thoughts on the problem, I have no confirmation from Tacx on this. Unfortunately beta-testers are often not in the loop either.
Has anyone else noted that when the Pause-Stop Training pop-up shows that the heart-rate displayed is not the current value. By the end of the pause interval the heart-rate updates to the correct value.
Does the Quarg suffer from more connection problems than a Powertap? Anyone compared the two?
Currently with my Powertap the issues are still the irritating Pause pop-up about every 5 minutes and the occasional loss of brake connection, which is much more frustrating (even with the Suunto stick and close proximity of the brake to the stick). I am checking the USB sleep setting currently. First one and a half hour run was fine.
8GB RAM
4GB Ram
Windows 7 32-bit
TTS 3.11 & TTS 4.3
Post by ms6073 » Wed Nov 14, 2012 12:37 am
I have a Suunto MoveStick Mini on an extension cable clipped to deraileur cable so that the stick touches the underside of the Bushido Handlebar controller and still get an occasional pause popup when training connected to TTS. Now I cant comment on the Powertap versus Quarq, but with my SRM, although I typically am limited to 45-60 minute Catalyst training sessions, I have noted HR being a bit out of sync on the rare occasion i get the popup. This also has me wondering if these 'sync' issues are what causes the lack of stability of the motorbrake resistance while paired with an ANT+ powermeter?
Locked
Users browsing this forum: No registered users and 19 guests
