NEO not broadcasting Ant+ ?? (can't pair)
BikerPa
Post by BikerPa » Sat May 12, 2018 7:19 pm
Hi there, newby Q on here having moved from a dumb Elite to a NEO so please be kind if it's a stupid one. :wink:
Anyway I have a brand new NEO which pairs/works fine via BT for Zwift on iOS (done a couple of rides), but it does not seem to be broadcasting Ant+ at all.
I've tried to pair via Ant+ passively (without any BT connection made) to both my Garmin FR935 watch & my CABLE Ant+ to BT repeater & neither can find the NEO when they scan.
I've updated the NEO's Fw successfully but this has made no difference, so has anyone got any suggestions? or have I likely got a defective unit?
TIA
Mike (in the UK)
NEO
Re: NEO not broadcasting Ant+ ?? (can't pair)
Post by mcorn » Sun May 13, 2018 4:44 am
BikerPa
Post by BikerPa » Sun May 13, 2018 9:34 am
Contact support@tacx.com
I already have thank you, I’m awaiting a response, but was hoping someone might have had some insight whilst i wait 😔
NEO
Post by ms6073 » Mon May 14, 2018 9:44 pm
Exactly what are you trying to accomplish? If you are trying to connect to/control the Neo itself as an ANT+ FE-C trainer, then the first question I would ask was did Garmin ever push a firmware update to add ANT+ FE-C compatibility to the FR935? As for other device connections, the FR935 should be able to scan for and connect to the Neo as an ANT+ Powermeter as well as a combined ANT+ Speed/Cadence sensor.
BikerPa
Post by BikerPa » Mon May 14, 2018 10:28 pm
I was trying to get Zwift via BT controlling the Neo, & my FR 935 passively reading power/speed/cadence via Ant+ just as you suggest.
Maybe it was a glitch as the FR935 couldn't 'hear' the Ant+, I have now however got it working as I wanted.
Worryingly Tacx support stated no Garmin FR's could read the Neo's Ant+ broadcast :shock: when I know all that have a bike profile can!
NEO
Post by ms6073 » Tue May 15, 2018 2:46 pm
Keep in mind that English is not native language spoken/typed by members of the support team and often times the intent of a reply is lost in translation. I suspect that Tacx was implying the same thing I mentioned about the FR935 not supporting the ANT+ FE-C protocol which would allow you to do things like control the Neo from the watch or even train using an workout that is stored on the watch.
Users browsing this forum: No registered users and 21 guests
