Raid Pyrenees Stage 13
Wyatt49
Post by Wyatt49 » Wed Feb 13, 2019 10:36 pm
I rode this course today on my Tacx Neo. Throughout the ride, through the crank, it felt like riding on cobbles. I could only maintain the appropriate power and speed by using the big rind and the top 5 gears plus increased cadence. Very strange to climb 7-10% inclines with such gearing; normally small ring, lowest gears and lower cadence.
I thought there was a problem with my turbo, maybe the cassette had loosen but after the ride I loaded a previous ride that I had done and everything was working as expected!
I can only surmise that there is an issue with the Stage 13 interaction with the TDA? Is this a known problem please?
ps I have had no problems with all the stages 1-12.
Re: Raid Pyrenees Stage 13
Post by Tacx Video Production » Wed Feb 13, 2019 10:51 pm
It’s not the film these are all pre tested by a group of old timers, to me it sounds like the Neo got some kind of different signal. I’ve had this also a few weeks ago, you can feel the normal inertia is gone & it’s a little rough. If it happens again try to recognise early & turn it all of and relink.
There is probably a better solution but for me it vanished by its self & could not repeat it
Wyatt49
Post by Wyatt49 » Thu Feb 14, 2019 12:00 am
Many thanks for your response, you described how it felt exactly. I’ll follow you advice if it happens again.
