HeartRateMonitor ID
Pierre Noiret
HeartRateMonitor ID
Post by Pierre Noiret » Sun Dec 30, 2018 12:10 am
I could not get a heart rate visible today.
As I have a few sensors lying around in the same room as where the Tacx is used, it would be helpful to have the device identified by number instead of the generic "TreK" HRM. This would help sorting out the issue.
There is a HR sensor detected, but without a heart rate appearing.
Or is there a way to find out somewhere ?
Thanks!
Pierre
Re: HeartRateMonitor ID
Post by mcorn » Mon Dec 31, 2018 4:02 pm
Thanks!
Pierre
I have seen the same issue with other sensors as well. I have requested that TDA display ID numbers for all devices. As i recall TTS4 does this.
It probably wouldn't hurt if other customers made the same request to support@tacx.com. If you only make the comment on this forum, it may not be heard.
