720p videos on big screen - Solved
xraiders
Post by xraiders » Mon Nov 12, 2018 9:29 pm
1080 vs720p
I'm usuing 720p videos but i'm not satisfied for the quality at 720p, the video show many artifacts, in 1080p the quality is better?
David
Re: 720p videos
Post by mcorn » Mon Nov 12, 2018 9:32 pm
1080 vs720p
David
Yes, the 1080P is higher quality, but it is mostly noticeable on larger monitors (32" and up). If you are on a laptop, you won't notice much difference, but the easiest thing is to try one. 1080P does require more computer horsepower and takes longer to download as the file size is larger.
Re: 720p videos
Post by Tacx Video Production » Mon Nov 12, 2018 10:05 pm
The Full HD files are at least 2x larger files then the 720p so you will have a much better quality image for sure.
xraiders
Re: 720p videos
Post by xraiders » Mon Nov 12, 2018 10:10 pm
I use 80 inch screen hd 720 videoprojector but video quality in 720p is poor
Re: 720p videos
Post by Tacx Video Production » Mon Nov 12, 2018 10:26 pm
Well even with a 720p projector going to the Full HD would double the bitrate, it should increase the contrast & massively decrease the artifacts..I can not imagine watching the 720p on a 80" display. Obviously the image from a video file that is Full HD & more then twice the bitrate will be massively sharper with a Full HD projector at 80".
xraiders
Re: 720p videos
Post by xraiders » Mon Nov 12, 2018 10:29 pm
My projector is hd not full hd
Re: 720p videos
Post by Tacx Video Production » Mon Nov 12, 2018 10:50 pm
Normally there can not be any visible artifacts at all if your downscale our full HD to 720p, its just going to be half as sharp.
Which rides are you looking at? Recent films made since 2016 come from 4K cinema camera & have a fair bit less compression & look sharper, although I think with a 720p display its not going to be a huge difference....rule of the thumb is 'bits = quality' & if you double the bits you will increase the quality ;-).
Re: 720p videos
Post by mcorn » Mon Nov 12, 2018 10:53 pm
That is likely a contributing source of quality issues. If your projector is 720p/1080i, then an HD (1080P) may not show much improvement, but I would still give it try to see what happens. If you have a 16:10 projector (1280×800, 1440×900, etc.), then you might get some improvement. Phil can correct me, but my guess is his SD videos were mostly captured with a higher resolution and have been downscaled for SD.
Re: 720p videos
Post by Tacx Video Production » Mon Nov 12, 2018 11:11 pm
Yes its all downscaled & for the last 3 years its downscaled from 4K, Im 100% sure that going with the FullHD will remove more or less all the artifacts as 720p does have artifacts, the file size is often more then half the size of the Full HD...your going to see them in all their gory detail with a massive 80" display. Going Full HD will mean your only downscaling. If its artifacts that you want to remove then doing this should be the solution ;-).
xraiders
Re: 720p videos
Post by xraiders » Mon Nov 12, 2018 11:27 pm
The Resolution is 1280x800, i Will try the fhd subscriptio, also on my 23 inch monitor 720p is too compressed
Re: 720p videos
Post by Tacx Video Production » Mon Nov 12, 2018 11:39 pm
Well your the reason we have a Full HD version of each film, here is a handy list I posted in another thread just now where you can see which films are made in 4K, you maybe able to see a difference in quality even at 720p
T2055.56 - 0001 - Marmotte 2 - Col du Télégraphe
T2055.57 - 0001 - Marmotte 3 - Col du Galibier
T2055.58 - 0001 - Marmotte 4 - Alpe d'Huez
T2058.42 - 0001 - Etape du Tour 2017 - Col d'Izoard, Guillestre 4K
T2056.26 - 0001 - Cormet de Roselend Stage 1 - Col du Pré 4K
T2056.27 - 0001 - Cormet de Roselend Stage 2 - Roselend Summit 4K
T2058.57 - 0001 - Provence - Mont Ventoux, Malaucéne 4K
T2058.58 - 0001 - Provence - Chalet Reynard to Malaucéne 4K
T2058.49 - 0001 - Gorges du Verdon 4K
T1957.28 - 0001 - Dordogne - Cycle Tour
T2056.38 - 0001 - Vallée du Lot - Cycle Tour
T2058.20 - 0001 - Normandy, Mont Saint Michel - Cycle Tour 4K
T2056.35 - 0001 - Col de Sarenne 4K
T2056.36 - 0001 - Villard-Notre-Dame 4K
T2058.44 - 0001 - Risoul, Guillestre 4K
T2058.45 - 0001 - Gorges du Tarn Cycle Tour 4K
T2056.23 - 0001 - Etape du Tour 2018 - Col des Glieres 4K
T2058.52 - 0001 - Gargano National Park Stage 1, Vieste 4K
T2055.24 - 0001 - Passo dello Stelvio, Prato
T2058.17 - 0001 - Bologna - City Trip 4K
T2058.06 - 0001 - Lombardy - Lago d'Iseo - Cycle Tour
T2058.79 - 0001 - Zeeland - Cycle Tour 4K
T2058.70 - 0001 - Tour of Majorca Stage 1 - Porto Cristo
T2058.70 - 0001 - Tour of Majorca Stage 2 - Montuiri
T2058.65 - 0001 - Mur de Huy 4K
T2058.66 - 0001 - Dinant to Namur - Cycle Tour 4K
T2058.90 - 0001 - Kühtai, Oetz - Training with Lotto Jumbo 4K
T2058.92 - 0001 - Kitzbuheler Horn 4K
T2058.94 - 0001 - World Championship Innsbruck 2018 Road Race 4K
T2058.82 - 0001 - Grindelwald, Grosse Scheidegg 4K
T2058.85 - 0001 - Innertkirchen, Susten Pass 4K
T2058.86 - 0001 - Appenzell - Cycle Tour 4K
T2058.80 - 0001 - Grindelwald, Valley Cycle Tour 4K
T2055.18 - 0001 - Swiss Alps Stage 1 - Gotthard Pass, Airolo 4K
T2058.81 - 0001 - Grindelwald, Mannlichen 4K
T2059.96 - 0001 - Grosse Scheidegg Demo 4K
T2058.68 - 0001 - Schleck Gran Fondo 2017, Stage 1 4K
T2058.69 - 0001 - Schleck Gran Fondo 2017, Stage 2 4K
T2059.97 - 0001 - England, Gold Hill - Demo 4K
T2056.16 - 0001 - England, Box Hill - Cycle Tour 4K
T1957.27 - 0002 - Beaujolais - Cycle Tour
T1957.30 - 0002 - Corsica - Cap Corse - Cycle Tour
T2056.24 - 0002 - Etape du Tour 2018 - Col de Romme 4K
T2056.25 - 0002 - Etape du Tour 2018 - Col de la Colombiére 4K
T2056.29 - 0002 - Col de la Croix de Fer 4K
T2056.30 - 0002 - Iseran - Stage 1, Val-d'Isére 4K
T2056.31 - 0002 - Iseran - Stage 2, Val-d'Arc - CycleTour 4K
T2058.56 - 0002 - Provence - Mont Ventoux - Bedoin 4K
T2058.59 - 0002 - Provence - Bedoin to Mazan - Cycle Tour 4K
T2058.60 - 0002 - Carcassonne - Cycle Tour 4K
T2058.40 - 0002 - Col de la Cayolle, Barcelonnette 4K
T2058.43 - 0002 - Col de la Madeleine, Feissons 4K
T1956.83 - 0002 - Milan Sanremo
T2058.11 - 0002 - Tuscany - l'Eroica, Stage 1 4K
T2058.12 - 0002 - Tuscany - l'Eroica, Stage 2 4K
T2058.10 - 0002 - Rome City Trip 4K
T2058.53 - 0002 - Gargano National Park Stage 2, Peschici 4K
T2058.29 - 0002 - Noordzeeroute, Katwijk 4K
T2058.25 - 0002 - Gent City Trip 4K
T2058.67 - 0002 - Muur Van Geraardsbergen 4K
T2058.84 - 0002 - Innertkirchen, Grimsel Pass 4K
T2056.15 - 0002 - England, Exmoor National Park - Cycle Tour 4K
T2058.72 - 0002A - Tour of Majorca Stage 2a - Sant Salvador
T2058.74 - 0002A - Tour of Majorca Stage 2b - Puig de Randa
T2058.73 - 0002A - Tour of Majorca Stage 3 - Alaro
T2058.75 - 0002A - Tour of Majorca Stage 4 - Soller to Puig Major
T2058.76 - 0002A - Tour of Majorca Stage 5 - Sa Calobra
T2058.77 - 0002A - Tour of Majorca Stage 6 - Descent to Pollenca
0002A - Tour of Majorca Stage 6a - Formentor
T2059.01 - Running - Gent, Bourgoyen-Ossemeersen 4K
T2059.02 - Running - Gent, Blaarmeersen 4K
T2059.04 - Running - Oostende Sea Front 4K
T2059.05 - Running - Gent, Schelde Valley 4K
T2059.07 - Running - Kitzbuhel, Schwarzsee 4K
T2058.50 - 0003 - Gorges de Daluis 4K
T2056.28 - 0003 - La Rosiére 4K
T2056.34 - 0003 - La Bérarde 4K
T2058.89 - 0003 - Kaunertal Glacier Road 4K
T2058.95 - 0003 - World Championship Innsbruck 2018 TT 4K
T2058.24 - 0003 - Bruges City Trip 4K
T2056.17 - 0003 - England, New Forest - Cycle Tour 4K
T2055.84 - 0003 - Dolomites - Sella Ronda
T2055.70 - 0003 - Colle delle Finestre
T2055.91 - 0003 - Zoncolan
T2055.62 - 0004 - Passo del Mortirolo
T2058.18 - 0004- Tuscany, Florence - City Trip 4K
T2058.26 - 0004 - Maratea 4K
T2058.16 - 0004 - Tuscany - Chianti Classico 4K
T2058.13 - 0004 - Tuscany - l'Eroica, Stage 3 4K
T2058.51 - 0004 - Monte Terminillo 4K
T2056.19 - 0004 - England, Dorset Coast - Cycle Tour 4K
T2056.58 - 0004 - Schelde River to Kluisbergen - Cycle Tour 4K
T1956.74 - 0004 - Pacific Coast Highway - Stage 1
T2055.79 - 0005 - Lacets de Montvernier
T2055.66 - 0005 - Grand Départ 2015 Utrecht - Lars Boom
T2058.61 - 0007 - The Angliru 4K
T2058.62 - 0007 - Lagos de Covadonga 4K
T2058.63 - 0007 - San Sebastian, Jaizkibel 4K
T1957.33 - 0007 - Pico Veleta, Granada
T2055.93 - 0007 - Barcelona - City Trip
T2055.48 - 0000 - Gascony Tour Stage 1 - Saint Puy to Le Parré
T2055.49 - 0000 - Gascony Tour Stage 2 - Le Parré to Estampes
T2055.50 - 0000 - Gascony Tour Stage 3 - Estampes to Luc
T2055.51 - 0000 - Gascony Tour Stage 4 - Pyrenees Foothills
T2055.52 - 0000 - Gascony Tour Stage 5 - Hautacam
T2055.86 - SEP18 - Grossglockner North Side
T2056.61 - SEP18 - Grossglockner, South Side - Stage 1
T2056.62 - SEP18 - Grossglockner, South Side - Stage 2
T2058.88 - SEP18 - Hahntennjoch Pass, Elmen 4K
T2058.08 - SEP18 - Bavaria, Romantic Road
T2055.82 - SEP18 - California, Pacific Coast Highway Stage 2
T2056.54 - SEP18 - Tour of Flanders Fan Ride 2018 - The Final 4K
T2056.59 - SEP18 - Cycling through Water, Bokrijk - Cycle Tour 4K
T2056.65 - SEP18 - England, Peak District - Holme Moss 4K
T2056.77 - PRO18 - Training with Bob Jungels, Part 1 4K
T2056.78 - PRO18 - Training with Bob Jungles, Part 2 4K
T2056.79 - PRO18 - Training with George Bennet, Andora 4K
T2056.80 - PRO18 - Training with Sabrina Stultiens, Limburg 4K
T2055.38 - OCT18 - Raid Pyrenees Stage 01 - La Tour Madeloc
T2055.39 - OCT18 - Raid Pyrenees Stage 02 - Languedoc Roussillon
T2055.40 - OCT18 - Raid Pyrenees Stage 03 - Col de Jau
T2055.41 - OCT18 - Raid Pyrenees Stage 04 - Col de Pailheres
T2055.22 - OCT18 - Raid Pyrenees Stage 04A - Plateau de Beille
T2058.14 - OCT18 - Lombardy, Madonna del Ghisallo 4K
T2058.15 - OCT18 - Lombardy, Muro di Sormano 4K
T2058.19 - OCT18 - Normandy, Omaha Beach 4K
T2055.83 - OCT18 - California, Yosemite 1 - National Park
T2055.19 - OCT18 - Swiss Alps Stage 2 - Furka Pass, Hospental
T2055.60 - OCT18 - Provence - Gorges de la Nesque
T2058.27 - NOV18 - Amsterdam City Trip 4K
T2056.41 - NOV18 - Atlantic Coast - Stage 1 - Skibbereen
T2059.03 - NOV18 - Running - Gent, Watersportbaan 4K
T2055.95 - NOV18 - Andalusia - Caminito del Rey Ardales
T2058.34 - NOV18 - Vosges, La Planche des Belles Filles 4K
T2055.42 - NOV18 - Raid Pyrenees Stage 05 - Col de Lers and Agnes
T2055.43 - NOV18 - Raid Pyrenees Stage 06 - Col de Catchaudégué
T2055.44 - NOV18 - Raid Pyrenees Stage 07 - Col de Portet d'Apset
T2055.45 - NOV18 - Raid Pyrenees Stage 08 - Port de Bales
T2055.46 - NOV18 - Raid Pyrenees Stage 09 - Col de Peyresourde
T2056.82 - NOV18 - Raid Pyrenees Stage 08a - Superbagneres
T2055.47 - NOV18 - Raid Pyrenees Stage 10 - Col d'Aspin
T2055.23 - NOV18 - Raid Pyrenees Stage 11 - Col du Tourmalet
Re: 720p videos
Post by mcorn » Tue Nov 13, 2018 12:11 am
I would download an HD demo and try it. With only 800 lines in your projector, you are not getting much above 720.
Re: 720p videos
Post by Tacx Video Production » Tue Nov 13, 2018 12:24 am
Mike I think the Demo rides are all 720p he would need to just take a months full HD subscription. Ive said that going Full HD will remove more or less all the visible compression artifacts. Obviously, a 720p film with Artifacts of which there are will be visible on a huge display like he has...he needs the Full HD which when downscaled will not have compression artifacts that the 720 has, it will be just losing half its sharpness..
Re: 720p videos
Post by mcorn » Tue Nov 13, 2018 1:18 am
I thought there were HD demos. But if not, you are right. There is often this trade-off between sharpness and artifacts. You can gain one at the expense of another.
xraiders
Re: 720p videos
Post by xraiders » Tue Nov 13, 2018 8:34 am
Thank you very much, afternoon I upgrade my subscription and try the new configuration
xraiders
Re: 720p videos
Post by xraiders » Tue Nov 13, 2018 8:20 pm
just completed the Flanders tour in 1080p version!! WOW the bitrate now is ok the video with 720p projector is perfect, video in 720p are too low bitrate, bad quality also for 23 inch
xraiders
Re: 720p videos on big screen - Solved
Post by xraiders » Sun Nov 25, 2018 10:59 pm
During black friday I bought a 4k 65 inch display when movies in 4k will arrive?
David
Post by Tacx Video Production » Mon Nov 26, 2018 10:19 am
No idea, Every ride filmed in the last years has a 4K version, we have 4k in closed beta since the start for PC (not Mac) but never really had a discussion with Tacx about their plans for it. If they did do it there will be a extra cost as these are twice the size of the Full HD. Just now most the customers are content with crappy 720p sadly although it seems the % going for the full HD is growing
Zouf
Post by Zouf » Mon Nov 26, 2018 3:40 pm
720p ain't so crappy... given the exquisite film contents and the very small amount of oxygen left in my brain during most rides, the image quality is great, even on a 55in TV.
xraiders
Post by xraiders » Tue Nov 27, 2018 8:58 pm
i'm a film maker, is possible to know the shooting system? is it an electric bike?
https://www.youtube.com/watch?time_cont ... SWxAhMtSUQ
