Tacx Cycling app on pc not able to find Tacx Flux
willem123
Post by willem123 » Thu Sep 27, 2018 6:35 pm
Hello,
On the computer TTS4 (latest version) is working good. I installed the cycling app. When I start
the app the search-window stays empty: no Flux trainer.
I closed the app and I removed the devices under TTS4 and started the app again.
No succes. What am I doing wrong or isn't the Flux working with the app.
Willem
PC: Intel Q8200, 12 GB Ram MSI p45D3 Neo-F
Re: Tacx Cycling app on pc not able to find Tacx Flux
Post by Alex Masalovich » Thu Sep 27, 2018 7:48 pm
Probably, you mean TDA, not TCA.
TDA works using the Bluetooth protocol. Do you have a transmitter to work on this protocol?
Post by Spiix » Fri Sep 28, 2018 11:49 am
Like Alex says, TDA only works over Bluetooth so make sure you're using that instead of ANT
If so, is the firmware of your flux up to date ?
willem123
Post by willem123 » Fri Oct 05, 2018 5:53 pm
Thanx. So far.
First I tried my phone. I also succeeded to update the firmware. I only use the utility.
I found another (older) bluetooth dongle. I also had a problem with the computer connecting
to the MicrosoftStore. I had to remove the nic from the devices.
Both dongles do not work. I ordered a new dongle.
Willem
