no readings from Neo after connecting via blue tooth
Gordonk
Post by Gordonk » Sun Sep 16, 2018 6:20 pm
windows 10 external blue tooth dongle. When I go to the device screen the Neo is there and I select all but there seems to be no transmission of data from the Neo. When I open a film and pedal nothing happens, it stays on the pedal to start or escape message.
When I look at the blue tooth settings in windows the Neo appears but under the driver details there is a warning message that a kernal was not migrated saying it was an ambiguous kernal and further actions are needed to install.
AMD Phenom X2 1055T 6 core
8G RAM
XFX Radeon HD 6950 1Gig video
60 Gig SSD harddrive for OS
1 Terabyte storage drive
Windows 7 64 bit
FORTIUS MOTORBRAKE
TTS 4.9.1
TTS3 3.12
Re: no readings from Neo after connecting via blue tooth
Post by Tacx Video Production » Sun Sep 16, 2018 7:00 pm
The top right there is a support button be sure to send the question via this. Tom is the guy you need if you can find him on the FB pages. But I think Tacx support will by now have a good idea of how to solve this one....Me Ive no idea what that error message means. Have you tried the dongle with any other software? I would try to google the error also as its Sunday.
Post by mcorn » Sun Sep 16, 2018 8:54 pm
On occasions, I have had similar problems, but they are usually resolved by rebooting the BT transmitter and brake (unplugging, then replugging) and sometimes rebooting the PC as well. Be sure there are no other Bluetooth or ANT+ devices trying to access the brake or other sensors.
Gordonk
Post by Gordonk » Mon Sep 17, 2018 6:06 pm
Thank you for the suggestions. the problem is resolved. I believe there was a conflict between my phone and the computer. Once I turned blue tooth off on my phone, then deleted the Neo blue tooth connection from the computer and rebooted every thing and repared the neo with the computer everything is now working.
Gordo
8G RAM
Windows 7 64 bit
FORTIUS MOTORBRAKE
TTS 4.9.1
TTS3 3.12
Post by mcorn » Mon Sep 17, 2018 6:52 pm
Gordo
Generally, if it is only a sensor (like heart rate or speed), multiple devices can access the sensor at the same time, including doing both BT and ANT+ at the same time. But if the device also receives signals and acts on them, you can get problems. Your NEO brake both sends and receives signals.
bigskypylot
Post by bigskypylot » Wed Oct 10, 2018 7:21 pm
Same thing is happening to me. I rebooted, unplugged and still doesnt want to connect. It shows the Tacx Neo and simulator. The simulator connects while the Neo doesnt. The bluetooth light on the Neo is illuminated. It will not connect in Rouvy either. I ordered a new BT4.0 Dongle as I'm using an old laptop circa 2013 running windows 10. Perhaps that may help? Is there something going on in the Neo itself?
Post by mcorn » Wed Oct 10, 2018 8:46 pm
On occasion I have TDA BT connection issues. To remedy I do the following:
1. Close TDA
2. Unplug BT transmitter and then restart.
3. Unplug Brake and then restart.
4. Restart TDA
5. Go to Device page
6. Select select all for Neo (not simulator) - when Neo is both recognized and connected, NEO symbol will change from greyed to bright
7. Turn crank to confirm you are receiving NEO data
8. Confirm HR and any other sensors are also connected (going from grey to bright)
bigskypylot
Post by bigskypylot » Thu Oct 11, 2018 12:52 am
I'll try again but none 0f that worked when I tried it. ANT+ for TTS4 isn't working either or with Rouvy.for that matter.
Post by mcorn » Thu Oct 11, 2018 1:37 am
This is beginning to sound like some other kind of problem. Have you tried any of the Tacx mobile apps. I would start with the utility app. I assume you are not trying to use ANT+ and BT transmitters at the same time on your computer.
bigskypylot
Post by bigskypylot » Thu Oct 11, 2018 3:21 pm
ANT+ dongle is unplugged. Tried to use TDA on my phone and does not find TACX NEO.
bigskypylot
Post by bigskypylot » Thu Oct 11, 2018 3:58 pm
Tacx utility app tells me to contact tacx. I have Paul from Clever training trying to help me out. Going to try new bluetooth dongle on Friday when it arrives
bigskypylot
Post by bigskypylot » Thu Oct 11, 2018 4:58 pm
Trying to attach screenshots but wont let me. I'm convinced it's a bad unit
Post by Spiix » Thu Oct 11, 2018 5:29 pm
It sure sounds like something bad happened to the trainer.
I would suggest contacting Tacx support https://support.tacx.com/hc/en-us
bigskypylot
Post by bigskypylot » Thu Oct 11, 2018 10:09 pm
I just got it a month ago. It happened the first time I used the TDA lol
Post by mcorn » Thu Oct 11, 2018 10:45 pm
Really would not have anything to do with TDA. Just a coincidence. But it is very disappointing to have an expensive trainer fail quickly.
Even if you are working with your dealer, it wouldn't hurt to contact Tacx Support at the link above or at support@tacx.com. In my experience, dealers often do not know much about a product although they may be the best place to get warranty service as the dealer can run interference for you.
bigskypylot
Post by bigskypylot » Sun Nov 04, 2018 5:36 pm
I had to unplug and let sit several times but seems to be working for now
Post by mcorn » Sun Nov 04, 2018 8:55 pm
Electronic devices do not heal themselves with rest, although occasionally a defective device will work when cold and not after heating up. Bebooting really only requires unplugging for a few seconds. So, if this is now working while warm, I think there may be something else going on in your setup in terms of interference from other Bluetooth sources.
Does your laptop also have a built-in Bluetooth transmitter? If it does, be sure it is disabled so you are only using your external BT transmitter. You may have to go into your laptop's BIOS to disable a built-in Bluetooth transmitter.
Users browsing this forum: Baidu [Spider], sanch3z and 3 guests
