TDA GPS rides
afnug
TDA GPS rides
Post by afnug » Thu Feb 15, 2018 6:53 pm
How do you start a GPS ride in TDA, I can import a GPS file, but can't figure out how to start the ride, I am still using the Beta app in windows, do I have to remove the Beta and replace it with an updated version ?
I have not taken out a subscription yet, I ride mainly GPS in TTS 4 so wanted to compare.
Re: TDA GPS rides
Post by Spiix » Fri Feb 16, 2018 10:51 am
TDA doesn't support GPS rides (yet).
It's purely a video application right now
marcus.hopkins
Re: TDA GPS rides
Post by marcus.hopkins » Fri Feb 16, 2018 11:01 am
You can ride your imported GPS ride using the Tacx Training App for now.
afnug
Re: TDA GPS rides
Post by afnug » Fri Feb 16, 2018 9:32 pm
i was looking at this on the Tacx website and it suggests it supports GPS in windows, or have I got it wrong.
https://tacx.com/product/tacx-software/
afnug
Re: TDA GPS rides
Post by afnug » Fri Feb 16, 2018 9:33 pm
Do you mean can't ride ?
if you can ride GPS how ?
Re: TDA GPS rides
Post by mcorn » Fri Feb 16, 2018 9:37 pm
You have got it wrong. Look at the column for TDA. It does not indicate GPS support.
afnug
Re: TDA GPS rides
Post by afnug » Fri Feb 16, 2018 9:46 pm
So does that mean GPS is available to ride on phone and tablet ?
Re: TDA GPS rides
Post by Spiix » Mon Feb 19, 2018 10:57 am
As far as I know, TTS4 should be able to as well. Though it's not connected to the cloud.
You'll have to import the GPS file into TTS4 itself
tiredlegs
Re: TDA GPS rides
Post by tiredlegs » Mon Feb 19, 2018 6:35 pm
You can ride GPS on the Tacx Training App. You need to login to your Tacx Cloud and in the left hand pane select 'Create Workout'. You can then import a gpx file into the Tacx Cloud (having created one using mapping software or downloaded ride data). You can then smooth the gps data (three options available) and then click on 'Start Upload'. Once it's done the GPS route will appear in your workouts on the Tacx Cloud. All you need to do then is open TTA up and select 'Workouts' and your newly created GPS ride will appear. You then select this GPS ride and use it to train.
afnug
Re: TDA GPS rides
Post by afnug » Tue Feb 20, 2018 10:40 am
Thanks all for the replies, I seem to have confused myself with this, and now know that you can ride GPS in TTA and not TDA, it doesn't help in IMO that the TDA windows program is referred to as an app.
Re: TDA GPS rides
Post by mcorn » Tue Feb 20, 2018 5:54 pm
The Windows app concept and terminology comes from Microsoft, not Tacx. Windows 10 apps are different than Windows 10 programs as the apps are distributed through the Microsoft store and are a different platform.
afnug
Re: TDA GPS rides
Post by afnug » Fri Feb 23, 2018 2:59 pm
I didn't know that, I just assumed because it runs on windows 10, it is a windows program, thanks for the info.
Re: TDA GPS rides
Post by mcorn » Fri Feb 23, 2018 5:37 pm
Well, it is a Windows 10 program in the general sense, but there is this category of Windows 10 program called a Windows app which Microsoft has been increasingly pushing for a variety of reasons. It is supposed to be more secure among other things as it is available only through the Microsoft store and presumably passes various security and quality requirements.
