Choppy playback - Solved
formula1
Post by formula1 » Thu Nov 08, 2018 6:53 pm
I've been having some issues with the TDA with choppy, hesitating video playback during rides. It looks like it skips a few frames every few seconds. It's still usable, but gets annoying. I don't have a nice smooth video playback. I've tried deactivating antivirus processes & deactivating widgets. I've tried to bring my laptop closer to the trainer, tried bluetooth dongles and internal bluetooth, nothing seems to stop the choppy feel to the video. If I play the downloaded video outside of TDA, it plays nicely. If I use it in the app, it's choppy. I'm guessing it's using alot of resources that my laptop cant handle, or some issue is at play. Has anyone else had this issue & fixed it? thanks!
Re: Choppy playback
Post by mcorn » Thu Nov 08, 2018 8:24 pm
The first thing I would look at is your laptop specs: CPU, memory, video card (particularly CPU and video).
Which videos are you downloading - HD or SD? If SD works okay, then your laptop specs are likely the issue.
TDA is not a low resource program and as features have continued to be added, it seems to require more.
You can check resource utilization using the Performance Monitor built into the Task Manager of Windows 10. (Enter crtl-alt-del, select Task Manager and then the Performance tab). You can run the Performance Monitor on top of TDA (to to options and select Always on Top) and watch it while you are using a video. If CPU and GPU levels are in the 95%+ range, then you have a problem.
formula1
Re: Choppy playback
Post by formula1 » Fri Nov 09, 2018 3:22 am
Thank you for your reply. I'm running the software on a laptop. Intel Core i3-5020u CPU, 2.20 GHZ with 8 GB installed Ram, x64 based processor. I'm wondering if its sufficient. Task Manager is showing only 10% CPU usage, 3% GPU & 60% RAM usage when running Tacx. I'm only using SD videos. I was sure my hardware would have been sufficient, but I guess not. I also made sure all drivers are up to date.
Re: Choppy playback
Post by mcorn » Fri Nov 09, 2018 4:36 am
Not sure what to say. Although your CPU is not overpowering, your low CPU usage indicates no issue. When you click on the GPU in the left hand column of the performance tab, you should see a number of GPU graphs (3D, copy, video encode, and video decode). The critical one is video decode. What % does it show?
Your memory seems a bit high. You probably have shared memory, some of which is dedicated to the GPU. What GPU chip do you have? Can you allocate more memory to the GPU? If your video decode is high, allocating more to the GPU might help.
formula1
Re: Choppy playback
Post by formula1 » Mon Nov 12, 2018 6:51 pm
I'm not sure, but may have zeroed in on the issue, but not sure if its related to the trainer or software. I looked at my Strava feed & noticed my speed graph, it looks like a clean pattern of my speed dropping about 5 km/hr every 5 seconds & then comes back up for another 5 seconds. It's a fairly even pattern of up/down, like a zig/zag. I'm assuming that's why my video keeps feeling like it's dropping frames & feels choppy. I've looked at other rides I did in TDA & the same up/down pattern in speed is noticed. Other rides I've done on Zwift don't have this jagged pattern. Could it be a bluetooth issue? I'm using the laptops internal adapter. I tried to upload a screen capture of the image but the board wont allow it.
https://www.strava.com/activities/1956828900/analysis
Re: Choppy playback
Post by Tacx Video Production » Mon Nov 12, 2018 7:50 pm
Normally the speed you see is calculated from the watts your producing & having looked at that data on your strava this looks fine, I think thats just a small export-related bug that's affecting a lot users data that's exported to Strava from the Tacx cloud.
The choppy playback your experiencing is probably more related to the ride your using which was filmed a bit fast from a car (Majorca Grand Tour Stage 1), its one of the older rides in the collection. Try something filmed from 'Bertha' our filming EBike these are filmed at a cyclists speed & your probably going to have at least 2x the frame rate. Any of the free demo rides. Anything with riders...You will probably like the City Trips try Bologna, Rome or Gent these are filmed slow...Training with George Bennet would be a good one also, he was pushing less then 200watts the whole ride even though its quite hilly...that was his recovery ride route.
formula1
Re: Choppy playback
Post by formula1 » Mon Nov 12, 2018 8:06 pm
Interesting, thank you for your guidance. I never thought of that. I'll download one these & give it a try. Do the film descriptions in TDA mention filmed with Bertha? I want to only download those if it's the case. I'll start with the ones you mentioned. Thanks again! Really appreciate your help.
Re: Choppy playback
Post by Tacx Video Production » Mon Nov 12, 2018 8:31 pm
No back when the app started & actually in our RLV Beta we have 4K versions of everything filmed by Bertha, I figured the 4K would act as a filter. But Tacx decided the 4K would be too costly right now to make available just at this time. So they are all a bit hidden. The best way is to browse the facebook pages like https://www.facebook.com/TacxRealLifeVideo/ Anything posted on there since the start of 2016 will have been filmed on Bertha.
Re: Choppy playback
Post by mcorn » Mon Nov 12, 2018 8:36 pm
Did you look at your video decode % in Windows Performance Monitor?
If the problem is what Phil suggests (a big mismatch in the frame rates due the source material shot at a much different speed than your riding), it should show up as a very high video decode %. If you video decode % is high regardless of the video you are using, then you are more likely to have a computer issue.
Re: Choppy playback
Post by Tacx Video Production » Mon Nov 12, 2018 8:39 pm
There we go thats whats inside TDA right now, anything marked with a 4K is filmed from Bertha :wink:
T2055.56 - 0001 - Marmotte 2 - Col du Télégraphe
T2055.57 - 0001 - Marmotte 3 - Col du Galibier
T2055.58 - 0001 - Marmotte 4 - Alpe d'Huez
T2058.42 - 0001 - Etape du Tour 2017 - Col d'Izoard, Guillestre 4K
T2056.26 - 0001 - Cormet de Roselend Stage 1 - Col du Pré 4K
T2056.27 - 0001 - Cormet de Roselend Stage 2 - Roselend Summit 4K
T2058.57 - 0001 - Provence - Mont Ventoux, Malaucéne 4K
T2058.58 - 0001 - Provence - Chalet Reynard to Malaucéne 4K
T2058.49 - 0001 - Gorges du Verdon 4K
T1957.28 - 0001 - Dordogne - Cycle Tour
T2056.38 - 0001 - Vallée du Lot - Cycle Tour
T2058.20 - 0001 - Normandy, Mont Saint Michel - Cycle Tour 4K
T2056.35 - 0001 - Col de Sarenne 4K
T2056.36 - 0001 - Villard-Notre-Dame 4K
T2058.44 - 0001 - Risoul, Guillestre 4K
T2058.45 - 0001 - Gorges du Tarn Cycle Tour 4K
T2056.23 - 0001 - Etape du Tour 2018 - Col des Glieres 4K
T2058.52 - 0001 - Gargano National Park Stage 1, Vieste 4K
T2055.24 - 0001 - Passo dello Stelvio, Prato
T2058.17 - 0001 - Bologna - City Trip 4K
T2058.06 - 0001 - Lombardy - Lago d'Iseo - Cycle Tour
T2058.79 - 0001 - Zeeland - Cycle Tour 4K
T2058.70 - 0001 - Tour of Majorca Stage 1 - Porto Cristo
T2058.70 - 0001 - Tour of Majorca Stage 2 - Montuiri
T2058.65 - 0001 - Mur de Huy 4K
T2058.66 - 0001 - Dinant to Namur - Cycle Tour 4K
T2058.90 - 0001 - Kühtai, Oetz - Training with Lotto Jumbo 4K
T2058.92 - 0001 - Kitzbuheler Horn 4K
T2058.94 - 0001 - World Championship Innsbruck 2018 Road Race 4K
T2058.82 - 0001 - Grindelwald, Grosse Scheidegg 4K
T2058.85 - 0001 - Innertkirchen, Susten Pass 4K
T2058.86 - 0001 - Appenzell - Cycle Tour 4K
T2058.80 - 0001 - Grindelwald, Valley Cycle Tour 4K
T2055.18 - 0001 - Swiss Alps Stage 1 - Gotthard Pass, Airolo 4K
T2058.81 - 0001 - Grindelwald, Mannlichen 4K
T2059.96 - 0001 - Grosse Scheidegg Demo 4K
T2058.68 - 0001 - Schleck Gran Fondo 2017, Stage 1 4K
T2058.69 - 0001 - Schleck Gran Fondo 2017, Stage 2 4K
T2059.97 - 0001 - England, Gold Hill - Demo 4K
T2056.16 - 0001 - England, Box Hill - Cycle Tour 4K
T1957.27 - 0002 - Beaujolais - Cycle Tour
T1957.30 - 0002 - Corsica - Cap Corse - Cycle Tour
T2056.24 - 0002 - Etape du Tour 2018 - Col de Romme 4K
T2056.25 - 0002 - Etape du Tour 2018 - Col de la Colombiére 4K
T2056.29 - 0002 - Col de la Croix de Fer 4K
T2056.30 - 0002 - Iseran - Stage 1, Val-d'Isére 4K
T2056.31 - 0002 - Iseran - Stage 2, Val-d'Arc - CycleTour 4K
T2058.56 - 0002 - Provence - Mont Ventoux - Bedoin 4K
T2058.59 - 0002 - Provence - Bedoin to Mazan - Cycle Tour 4K
T2058.60 - 0002 - Carcassonne - Cycle Tour 4K
T2058.40 - 0002 - Col de la Cayolle, Barcelonnette 4K
T2058.43 - 0002 - Col de la Madeleine, Feissons 4K
T1956.83 - 0002 - Milan Sanremo
T2058.11 - 0002 - Tuscany - l'Eroica, Stage 1 4K
T2058.12 - 0002 - Tuscany - l'Eroica, Stage 2 4K
T2058.10 - 0002 - Rome City Trip 4K
T2058.53 - 0002 - Gargano National Park Stage 2, Peschici 4K
T2058.29 - 0002 - Noordzeeroute, Katwijk 4K
T2058.25 - 0002 - Gent City Trip 4K
T2058.67 - 0002 - Muur Van Geraardsbergen 4K
T2058.84 - 0002 - Innertkirchen, Grimsel Pass 4K
T2056.15 - 0002 - England, Exmoor National Park - Cycle Tour 4K
T2058.72 - 0002A - Tour of Majorca Stage 2a - Sant Salvador
T2058.74 - 0002A - Tour of Majorca Stage 2b - Puig de Randa
T2058.73 - 0002A - Tour of Majorca Stage 3 - Alaro
T2058.75 - 0002A - Tour of Majorca Stage 4 - Soller to Puig Major
T2058.76 - 0002A - Tour of Majorca Stage 5 - Sa Calobra
T2058.77 - 0002A - Tour of Majorca Stage 6 - Descent to Pollenca
0002A - Tour of Majorca Stage 6a - Formentor
T2059.01 - Running - Gent, Bourgoyen-Ossemeersen 4K
T2059.02 - Running - Gent, Blaarmeersen 4K
T2059.04 - Running - Oostende Sea Front 4K
T2059.05 - Running - Gent, Schelde Valley 4K
T2059.07 - Running - Kitzbuhel, Schwarzsee 4K
T2058.50 - 0003 - Gorges de Daluis 4K
T2056.28 - 0003 - La Rosiére 4K
T2056.34 - 0003 - La Bérarde 4K
T2058.89 - 0003 - Kaunertal Glacier Road 4K
T2058.95 - 0003 - World Championship Innsbruck 2018 TT 4K
T2058.24 - 0003 - Bruges City Trip 4K
T2056.17 - 0003 - England, New Forest - Cycle Tour 4K
T2055.84 - 0003 - Dolomites - Sella Ronda
T2055.70 - 0003 - Colle delle Finestre
T2055.91 - 0003 - Zoncolan
T2055.62 - 0004 - Passo del Mortirolo
T2058.18 - 0004- Tuscany, Florence - City Trip 4K
T2058.26 - 0004 - Maratea 4K
T2058.16 - 0004 - Tuscany - Chianti Classico 4K
T2058.13 - 0004 - Tuscany - l'Eroica, Stage 3 4K
T2058.51 - 0004 - Monte Terminillo 4K
T2056.19 - 0004 - England, Dorset Coast - Cycle Tour 4K
T2056.58 - 0004 - Schelde River to Kluisbergen - Cycle Tour 4K
T1956.74 - 0004 - Pacific Coast Highway - Stage 1
T2055.79 - 0005 - Lacets de Montvernier
T2055.66 - 0005 - Grand Départ 2015 Utrecht - Lars Boom
T2058.61 - 0007 - The Angliru 4K
T2058.62 - 0007 - Lagos de Covadonga 4K
T2058.63 - 0007 - San Sebastian, Jaizkibel 4K
T1957.33 - 0007 - Pico Veleta, Granada
T2055.93 - 0007 - Barcelona - City Trip
T2055.48 - 0000 - Gascony Tour Stage 1 - Saint Puy to Le Parré
T2055.49 - 0000 - Gascony Tour Stage 2 - Le Parré to Estampes
T2055.50 - 0000 - Gascony Tour Stage 3 - Estampes to Luc
T2055.51 - 0000 - Gascony Tour Stage 4 - Pyrenees Foothills
T2055.52 - 0000 - Gascony Tour Stage 5 - Hautacam
T2055.86 - SEP18 - Grossglockner North Side
T2056.61 - SEP18 - Grossglockner, South Side - Stage 1
T2056.62 - SEP18 - Grossglockner, South Side - Stage 2
T2058.88 - SEP18 - Hahntennjoch Pass, Elmen 4K
T2058.08 - SEP18 - Bavaria, Romantic Road
T2055.82 - SEP18 - California, Pacific Coast Highway Stage 2
T2056.54 - SEP18 - Tour of Flanders Fan Ride 2018 - The Final 4K
T2056.59 - SEP18 - Cycling through Water, Bokrijk - Cycle Tour 4K
T2056.65 - SEP18 - England, Peak District - Holme Moss 4K
T2056.77 - PRO18 - Training with Bob Jungels, Part 1 4K
T2056.78 - PRO18 - Training with Bob Jungles, Part 2 4K
T2056.79 - PRO18 - Training with George Bennet, Andora 4K
T2056.80 - PRO18 - Training with Sabrina Stultiens, Limburg 4K
T2055.38 - OCT18 - Raid Pyrenees Stage 01 - La Tour Madeloc
T2055.39 - OCT18 - Raid Pyrenees Stage 02 - Languedoc Roussillon
T2055.40 - OCT18 - Raid Pyrenees Stage 03 - Col de Jau
T2055.41 - OCT18 - Raid Pyrenees Stage 04 - Col de Pailheres
T2055.22 - OCT18 - Raid Pyrenees Stage 04A - Plateau de Beille
T2058.14 - OCT18 - Lombardy, Madonna del Ghisallo 4K
T2058.15 - OCT18 - Lombardy, Muro di Sormano 4K
T2058.19 - OCT18 - Normandy, Omaha Beach 4K
T2055.83 - OCT18 - California, Yosemite 1 - National Park
T2055.19 - OCT18 - Swiss Alps Stage 2 - Furka Pass, Hospental
T2055.60 - OCT18 - Provence - Gorges de la Nesque
T2058.27 - NOV18 - Amsterdam City Trip 4K
T2056.41 - NOV18 - Atlantic Coast - Stage 1 - Skibbereen
T2059.03 - NOV18 - Running - Gent, Watersportbaan 4K
T2055.95 - NOV18 - Andalusia - Caminito del Rey Ardales
T2058.34 - NOV18 - Vosges, La Planche des Belles Filles 4K
T2055.42 - NOV18 - Raid Pyrenees Stage 05 - Col de Lers and Agnes
T2055.43 - NOV18 - Raid Pyrenees Stage 06 - Col de Catchaudégué
T2055.44 - NOV18 - Raid Pyrenees Stage 07 - Col de Portet d'Apset
T2055.45 - NOV18 - Raid Pyrenees Stage 08 - Port de Bales
T2055.46 - NOV18 - Raid Pyrenees Stage 09 - Col de Peyresourde
T2056.82 - NOV18 - Raid Pyrenees Stage 08a - Superbagneres
T2055.47 - NOV18 - Raid Pyrenees Stage 10 - Col d'Aspin
T2055.23 - NOV18 - Raid Pyrenees Stage 11 - Col du Tourmalet
updated today
formula1
Re: Choppy playback
Post by formula1 » Mon Nov 12, 2018 9:13 pm
Thanks again! That's a great list to use. And thanks mcorn for your guidance also! I'll have a look at the performance monitor while riding one of the Bertha videos to see what the video decode % is at. I didn't notice anything alarming when I tested it this weekend. I'll take a closer look, maybe I missed something.
formula1
Re: Choppy playback
Post by formula1 » Tue Nov 13, 2018 4:53 pm
I tried the Dinant to Namur yesterday evening (a Bertha production) and the video was so much better. No choppy video at all to report. I kept an eye on the video decode % in Windows Performance Monitor & nothing out of the ordinary there. I guess the few videos I had tried were all pre-Bertha productions filmed at a higher speed then I'm able to pedal :D & thus resulting in choppy playback for me. I was afraid my trainer or pc hardware were the problem, it wasn't. I'll just stick to the Bertha produced films. A big thanks to mcorn and to Tacx Video Production for both your inputs & getting me back on track in enjoying these great rides! :D
