ANT+ genius compatibility
miannini
Post by miannini » Mon Jan 22, 2018 6:33 pm
I have downloaded and installed the TDA. I tried to find my non-smart Genius ANT+, it showed a few times on the device manager, but, then it disappeared. Does anybody know if TDA is already compatible with "older" (mid-2015) non-smart trainers? Did you have success using it?
Thanks!
Re: ANT+ genius compatibility
Post by mcorn » Mon Jan 22, 2018 7:19 pm
Thanks!
As of today, a non-Smart ANT+ trainer (non-Bluetooth) is not support in TDA. No word on when, if ever, these older ANT+ only trainers will be supported.
Post by Alex Masalovich » Mon Jan 22, 2018 10:35 pm
Try to make a screenshot at the time of such recognition. It is very interesting.
Tommo
Post by Tommo » Thu Feb 01, 2018 11:44 am
The TDA guide statement on this makes it questionable whether ANT+ will ever be supported on TDA
Does it really only works on Bluetooth
The ANT+ developer (Dynastream) needs to develop a driver for UWP (development
environment for Microsoft, which Tacx Desktop app is using), which are not compatible with
the older ANT+ driver. Therefor the driver cannot be certified by Microsoft and cannot be
used under UWP for Windows 10 (were Tacx Desktop app has been build on). At this point
we are not sure when this can be implemented.
Neo Smart
TTS4 4.22.6.0
TDA
Windows 10 64bit
Intel Core i3 540 3.07ghz
4GB Memory
ASUS AMD Radeon R7 240 2 GB DDR3
BenQ W1070+ 1080P HD Projector
kostyap
Post by kostyap » Thu Feb 01, 2018 3:29 pm
Dynastream does not need/have to develop anything. They've already developed driver for Windows that is perfectly usable from desktop applications. The guilty party is Tacx/Their vendor who had for whatever reasons chosen UWP as their platform instead of standard desktop application. Their bad. This choice gives zero advantages and a whole host of limitations. Besides even for UWP if they really wanted to the issue is easily solvable.
Post by mcorn » Thu Feb 01, 2018 5:44 pm
https://www.thisisant.com/forum/adopt/v ... 6512/#7317
Choosing UWP has gotten TDA painted into a corner. I have no idea why Dynastream does not develop a signed driver for use with UWP. Seems like Dynastream is also painting itself into a corner as it is limiting ANT+ apps that can be sold in the Microsoft store.
Post by mcorn » Sat Feb 03, 2018 6:29 pm
Tacx Video Production wrote:
Sat Feb 03, 2018 5:18 pm
It all makes no difference anyway, Tacx missed the winter. Everyone will be out on road in a few weeks here..
This is not a one winter issue, it is all winters.
miannini
Post by miannini » Wed Feb 28, 2018 9:09 pm
My bad, in Win10, TDA does not shows my ANT+ roller. It shows on the iPad... Sorry for the confusion.
miannini
Post by miannini » Mon Apr 09, 2018 4:24 pm
Any news of the compatibility between TDA and older non-smart Tacx trainers? Did anyone from Tacx hear a word?
Post by mcorn » Mon Apr 09, 2018 4:58 pm
My impression is this is very unlikely to happen any time soon due to the choice to use the Microsoft UWP platform for TDA. It seems to not make much sense given the large base of ANT+ only hardware out there, but I have seen little public indication that this will be solved or that anyone is actually working on this. Dynastream, part of Garmin and the owner of ANT+, indicated two years ago that it was working on it, but that all seems to have fizzled. I suspect there are some major incompatibilities between the UWP platform and ANT+. There may be be someone else on the forum who better understands the technical issues.
tnikolai
Post by tnikolai » Thu Oct 11, 2018 11:51 pm
It possible!
UWP can communicate with Win32 process. So can do Win32 bridge for ANT+.
https://github.com/Microsoft/DesktopBri ... idgeSample or
https://blogs.windows.com/buildingapps/ ... g-project/
Post by Spiix » Fri Oct 12, 2018 9:40 am
It possible!
That is indeed part of the solution we are working on.
Sherani
Post by Sherani » Fri Dec 21, 2018 1:38 am
Hello Spiix,
are there any news concerning the compatibility between TDA and the ANT + protocol? There are many users who not only use older ANT+ only trainers, but who need to be able to pair other sensors such as HR strapss, speed / cadence sensors and power meters that only use the ANT+ connection.
Many thanks in advance for your reply.
Best regards.
Post by Spiix » Wed Jan 02, 2019 10:29 am
No news as far as I know, sorry
