create and run workouts
Questions and information about the Tacx.com website.
atortora81
Post by atortora81 » Mon May 28, 2018 8:52 pm
HI to all,
I bought a tacx vortex and I downloaded tacx desktop app.
In this app there are some video races but I don't need them I want to create my workouts.
I entered in the cloud function and I created some workouts.
My problem is: how can I run my workouts? I can run video races but I don't find a button to start my workouts
please help me
thank you
Alfredo
Re: create and run workouts
Post by Alex Masalovich » Mon May 28, 2018 10:37 pm
To do this, you need to use another application:
Tacx Training app or Tacx Cycling app
https://support.tacx.com/hc/en-us/secti ... aining-app
https://support.tacx.com/hc/en-us/secti ... ycling-app
atortora81
Post by atortora81 » Tue May 29, 2018 8:03 am
Hi, thank you forma your reply
These apps are for android phones. Unlucky I'm able to use only a windows PC... Is it possible to run workouts with a PC?
Post by mcorn » Tue May 29, 2018 5:56 pm
As Alex suggested, these are completely different programs and they do not "talk" to each other. The current capabilities of TDA are described in this manual:
https://tacx.com/support/Tacx_Desktop_app_manual.pdf
The Tacx Trainer Software 4 (TTS4) program does have a Catalyst module for creating your own workouts, but TTS4 is listed by Tacx as in "legacy status".
Post by Alex Masalovich » Tue May 29, 2018 6:46 pm
1) You can try the Android emulator:
https://www.androidauthority.com/best-a ... pc-655308/
2) You can use other programs from other developers, for example, the Golden Cheetah:
http://www.goldencheetah.org/
atortora81
Post by atortora81 » Wed May 30, 2018 8:32 am
I tried with golden cheat bit it doesn't see the vortex.
Today I will try with an android simulator and I'll let you know. Have you got any suggest about which emulator I should use?
Thank you again for your support.
Post by Alex Masalovich » Wed May 30, 2018 11:00 am
For the Golden Cheetah, you must use ANT+ antenna. To ensure there is no conflict, turn Bluetooth off entirely when training.
This is an unexplored jungle. No one has ever reported here on the successful use of the Android emulator.
atortora81
Post by atortora81 » Wed May 30, 2018 11:15 am
OK. In this case I will buy an ant+ and everything will work (I hope).
Just a last question...
In my first use of Cortex i used a video race and when the road go high the resistente of the Cortex go high.
Yesterday i used the same video race and when the road go high the speedy in video went down but the resistence did noto go up.... Maybe did i move some setting?
Thank you again
Post by Alex Masalovich » Wed May 30, 2018 11:35 am
This behavior is typical for the old firmware. But to update the firmware you need a smartphone or tablet and Tacx Utility app:
https://support.tacx.com/hc/en-us/secti ... tility-app
Post by mcorn » Wed May 30, 2018 7:15 pm
I have not had good luck with Android emulators.
There are a lot of inexpensive Android tablets with Bluetooth that will run the Tacx Android apps. But frankly, I don't think they are very interesting to use. It might make more sense to do this rather than spend money on an ANT+ antenna.
atortora81
Post by atortora81 » Thu May 31, 2018 8:38 am
Exactly... I bought an ANT+ antenna.... Hoping after everything is OK :D
Thank you again
Post by mcorn » Thu May 31, 2018 5:55 pm
Return to “Tacx website”
