screen size
screen size
i have tts4 advanced and i have upgraded to windows 10, but not sure if this has caused the problem, it may just be a settings issue, but i could do with a little help,
i cannot view the full screen i.e. to see the start button, (i have to scroll across and so lose the intro/cat/video boxes) i can change the screen size on monitor 4:3 or 16:9 i can change the tts settings to view full screen on/off but can't seem to find the proper solution could somebody please suggest a possible solution!
thanks in advance
thanks in advance
- Alex Masalovich
- Moderator
- Contact:
Re: screen size
I guess you have too low screen resolution in Windows settings. You might need to update your display driver by visiting the manufacturer's website of your graphics card.
- Nasz
- Moderator
- Contact:
Re: screen size
Sounds likelyAlex Masalovich wrote:I guess you have too low screen resolution in Windows settings. You might need to update your display driver by visiting the manufacturer's website of your graphics card.
_______o
_____~\<,_
____(_)/ (_)
Train hard, ride easy
_____~\<,_
____(_)/ (_)
Re: screen size
I couldn't argue with you as I'm not technically brilliant but it used to work fine. I bought the new comp with a graphics card better than Tacx spec. I was just wondering if was something the system alters when all these updates take place? and I need to alter some setting etc the system all works fine I just cant see the whole screen like I used too???
- Alex Masalovich
- Moderator
- Contact:
Re: screen size
You told us:
This is the beginning of your personal participation in the infinite perfection of all the software on your computer.stevewood668 wrote: i have upgraded to windows 10
- bigrichard
Re: screen size
It's not the resolution it's the scaling I believe.
NEO
TTS4 Version 4.22.0.0
42" Panasonic Plasma
Gigabyte G1 Sniper M3 Mobo
Intel core i7 3770K @ 3.9GHz
16GB RAM @ 1600 MHz
Nvidia GTX980 4095 MB
Samsung 840 Pro 256G hard drive
Corsair 860 PSU
Windows 7 Home Prem 64bit
16GB RAM @ 1600 MHz
Corsair 860 PSU
Re: screen size
"This is the beginning of your personal participation in the infinite perfection of all the software on your computer.
LOL never a truer word spoken.
I have simply changed to a 40" screen to test and low and behold all ok, but something must have changed as my smaller screen has been ok for the last few years.
never mind alls well that ends well thanks for your time and in put guys!
- Nasz
- Moderator
- Contact:
Re: screen size
Screen rescaling occurs when you change from a smaller monitor to a 40" screen. Even though the resolution may be the same.
_______o
_____~\<,_
____(_)/ (_)
_____~\<,_
____(_)/ (_)
