tyre pressure on trainer
vinay
Post by vinay » Tue Sep 17, 2013 9:52 pm
What tyre pressure do you recommend for the 26" Tacx trainer tyre? Usually I have my tyres at about 1.5 bar, but these are 2.2" to 2.4" wide (or wider on the bigger hitting bike). The Tacx tyre is incredibly narrow, so I bumped pressure up to well over 2.5 bar. Is that too much, to little or just right? Calibration index on my Bushido trainer is usually somewhere at 17 or 18 and I noticed in another thread (read only) that this index should be somewhere between 10 and 15. Does this mean I should raise my pressure or lower it? And by how much?
Re: tyre pressure on trainer
Post by malfukt » Wed Sep 18, 2013 1:16 am
60 - 90 PSI ........ 4 - 6.2 BAR
Would advise opt for higher pressure, adjust knob/nut under engagement handle to lower/increase tension to get required calibration figure
vinay
Post by vinay » Wed Sep 18, 2013 4:15 pm
Thank you, I'll try that!
jpalcover
Location: Swiss Alps (5,000 ft) and Pollensa, Mallorca, Spain (sea level). Occasionally in Paris or Royan.
Post by jpalcover » Wed Sep 18, 2013 5:02 pm
Recommended pressure for tyres of 700x23 dimension is around 8 Kg/cm2 (roughly 8 bars or 113½ lbs/sq. in.)
Running TTS4.19.1 on
WIN 10 PRO 64bit
i7-4790 4.0 GHz; 24GB RAM @ 1600 MHz; AMD Radeon R9 270 2GB
256 GB SSD (System) + 2TB HDD (data); BluRay drive
i-Genius (Brake fw: 1.1.325); Satori
Post by mcorn » Wed Sep 18, 2013 5:46 pm
vinay wrote:What tyre pressure do you recommend for the 26" Tacx trainer tyre? Usually I have my tyres at about 1.5 bar, but these are 2.2" to 2.4" wide (or wider on the bigger hitting bike). The Tacx tyre is incredibly narrow, so I bumped pressure up to well over 2.5 bar. Is that too much, to little or just right? Calibration index on my Bushido trainer is usually somewhere at 17 or 18 and I noticed in another thread (read only) that this index should be somewhere between 10 and 15. Does this mean I should raise my pressure or lower it? And by how much?
A narrow MTB tire, like the Tacx trainer tire, may not work on an MTB rim that is designed for very wide tires (over 2"). Did you check the spec on the Tacx trainer tire to see if it is suitable for your wider MTB rims?
Post by malfukt » Wed Sep 18, 2013 6:07 pm
I answered with pressures above as looked up 26 inch turbo trainer tyres & recommended pressures where those above post..
Repeated here : 60 - 90 PSI ........ 4 - 6.2 BAR
These are not road 700c x 23 tyres which run higher pressures 110 to 120 psi 6 to 8 bar
Post by mcorn » Wed Sep 18, 2013 7:00 pm
I was raising a fitment issue rather than tire pressure. Putting together a tire and rim not meant for each other can cause a tire blow-off or other problems. In general, a rim designed for a 2.2"+ tire would not be suitable for a 1.25" tire.
Post by malfukt » Wed Sep 18, 2013 7:07 pm
Sorry it was meant to clarify for jpacover as he put 700cx23 tyre pressures, dont think he had noticed that it is MTB 26 inch trainer tyre :)
Post by mcorn » Wed Sep 18, 2013 7:11 pm
Ah, yes I see.
vinay
Post by vinay » Fri Sep 20, 2013 9:19 pm
No worries, the rim is pretty narrow actually. I increased pressure to somewhere around 5 bar and the tyre stays put.
Never thought over 2" was considered very wide. Anything below 2.1" is considered narrow, nowadays ;).
