New Bushido
Gerald123
New Bushido
Post by Gerald123 » Wed Jan 19, 2011 9:50 pm
I purchased a new Bushido on the 2/1/2011 thinking I woul be be getting the 2011 model with the back light on the head unit.There are no problems with unit apart from the poor display.On further investigation I foun this Bushido to be manufactured in 2009.My question is should I have received a 2011 model,with new back light?Do I have a case to return this Model to the shop I bought it from?????
cyberjunk
Post by cyberjunk » Wed Jan 19, 2011 10:32 pm
What is the version of your firmware 5.004? Do you have a backlight display? If so then you have the most current Bushido.
Toshiba Tablet Notebook
connected to a 46" LCD monitor via DVI
Intel 2.8 Ghz Core Duo
4G RAM
On board graphics with shared memory
WIN 7 64 Bit Ultimate
Gerald123
Post by Gerald123 » Wed Jan 19, 2011 11:00 pm
No backlight display....
cyberjunk
Post by cyberjunk » Wed Jan 19, 2011 11:15 pm
Sounds like you have a 2009 Bushido head.
The 2010 head is not all its cracked up to be. Some might say you are lucky because unless you leave the backlight on you have no contrast.
If you what the newer head then I suggest you contact the compajy you purchased your unit from and see if they will exchange the head for you.
4G RAM
Gerald123
Post by Gerald123 » Wed Jan 19, 2011 11:17 pm
I have had no problems with it so far.I suppose I could live with it the way it is.
Thanks for the info.
Return to “Archives”
Users browsing this forum: Exabot [Bot] and 12 guests
