issue while paring with NEO Track
http://www.tacx.com/en/products/software/ant-open
NTU_bayang
Post by NTU_bayang » Fri May 12, 2017 8:13 am
I am trying to pair with Tacx NEO Track via ANT+ now
Does anyone know the channel configuration information (RF Frequency, Channel ID, Channel Period ...)
Thanks in advanced!
Re: issue while paring with NEO Track
Post by ms6073 » Fri May 12, 2017 12:14 pm
What are you trying to pair with?Although the Tacx Smart Trainers all broadcast standard ANT+profiles, since there is not an ANT+ profile for a steering unit, I am pretty sure that the Neo Track steerering unit still broadcasts via private ANT, which will mean it only works with Tacx Trainer Software 4.
TTS 4.19.1 | T2800 NEO Smart [formerly Bushido & Fortius]
MSI GS70 Laptop | Windows 10 x64
Intel Core i7-4710HQ 2.40 GHz | 16 Gb DDR3 1600 MHz
GeForce GTX 870M | 256 GB SSD x 2 RAID 0 + 1 TB HDD
NTU_bayang
Post by NTU_bayang » Mon May 15, 2017 3:28 am
thanks for your reply
does that mean I am not allowed to pair the NEO Track with my own developed software?
Post by ms6073 » Mon May 15, 2017 4:27 am
No, not at all. Simply means that the Neo Black Track dfoes not incorporate a known ANT+ profile, so you will have to divine what is being transmitted. :? Best I can do is suggest you take a look at Cowboy Coders project in which they decoded the private ANT communications for a legacy Bushido.
NTU_bayang
Post by NTU_bayang » Tue May 16, 2017 5:43 am
thanks so much for your help
I have found another way to play with the NEO Track
Return to “ANT+ Open Complete freedom using your software of choice”
