Bushido brake unit on Vortex frame
general chat
Moderators: malfukt, Steve Newton, Tacx support, mcorn, Tacx Moderator, Tacx Video Production, Nasz
stapes789
Post by stapes789 » Sat Oct 21, 2017 7:39 am
I have a Vortex Smart but have recently moved house and my new garage has no power. I therefore need a turbo that runs without power. Please could someone tell me if a Bushido Smart brake unit will fit on to a Vortex Smart frame? Looking at the photos, the only difference looks to be the colour?
Thanks in advance
Re: Bushido brake unit on Vortex frame
Post by Alex Masalovich » Sat Oct 21, 2017 10:04 am
You are right, the bracket on the frame looks the same:
But to confirm full compatibility requires an experiment or a request to the support@tacx.com.
stapes789
Post by stapes789 » Sat Oct 21, 2017 10:26 am
Thanks Alex, I will get in touch.
Post by mcorn » Sat Oct 21, 2017 5:54 pm
As far as I can tell, these frames are the same, other than the paint job. I think they are all based on the original Tacx Satori trainer. I have inter-changed Genius, Bushido and Vortex brakes on this frame.
P.S. Why not run a long extension cord out to the garage. It's a lot cheaper than a new brake. These trainers consume a very small amount of power, so you don't need a heavy cord. The Bushido is more finicky to use than the other trainers in my experience. Doing firmware updates can be difficult at times.
Post by Alex Masalovich » Sat Oct 21, 2017 6:26 pm
The frame of the Satori T1856 has a different design of bracket:
viewtopic.php?f=25&t=25300
But frame of Booster T2500 has the same design of bracket as the Genius, Bushido and Vortex:
https://tacx.com/wp-content/themes/tacx ... r_1411.pdf
Post by mcorn » Sat Oct 21, 2017 7:47 pm
You are right. The Satori frame is generally the same as for the Genius, Bushido, and Vortex, except the brake attachment portion on the rear of the frame is similar to the earlier Imagic/Fortius/Cycleforce frame (and similar magnetic trainers) that used the plastic extension pieces for different wheel sizes.
But I still believe that the Genius, Bushido and Vortex brakes use the same frame.
Return to “General”
