Problems with Streetview on GPS-rides since 15th February
Moderators: mcorn, Tacx Moderator, malfukt, Tacx support, Fortius Magical Man
Locked
mcinner
Post by mcinner » Wed Feb 15, 2017 4:19 pm
Hi!
Until yesterday (14th February) all worked well with GPS rides and Streetview.
Since today (15th) - out of the blue - Streetview-pics are loaded very slowly with a black frame when pictures are changing, and after a view minutes TTs4 crashes.
I'm wondering if this is a common problem caused by the handshaking with Google-Streetview or if it's a problem with my laptop (Win8).
(My internet is ok - 40 Mbps)
Enybody else?
Re: Problems with Streetview on GPS-rides since 15th February
Post by Lunatix » Wed Feb 15, 2017 5:40 pm
Is there anything in the logfile? CAuse we didn't change anything server side :)
mcinner
Post by mcinner » Wed Feb 15, 2017 5:54 pm
Thanks for reply.
Where do I find the logfiles?
Post by Alex Masalovich » Wed Feb 15, 2017 6:02 pm
The fastest access to this folder: copy here the path to it and paste it in the address bar of Explorer or browser.
Use the tag "Code" to publish the log.
mcinner
Post by mcinner » Wed Feb 15, 2017 6:18 pm
Thank you!
Here you are:
Code: Select all
[INFO  2017.02.15 16:19:47:9165] TRAINERSOFTWARE:  Version: 4.20.0.0 - Build date: Friday, July 15, 2016 11:59:20 AM UTC
[INFO  2017.02.15 16:19:47:9165] TRAINERSOFTWARE:  Started application. (C:\Program Files (x86)\Tacx\TacxTrainersoftware4\TrainerSoftware.exe)
[INFO  2017.02.15 16:19:47:9634] TRAINERSOFTWARE:  [OS] Microsoft Windows 8.1 64-Bit
[INFO  2017.02.15 16:19:47:9634] TRAINERSOFTWARE:  [OS] Application Elevated = False
[INFO  2017.02.15 16:19:47:9634] TRAINERSOFTWARE:  [OS] Application ElevationType = TokenElevationTypeDefault
[INFO  2017.02.15 16:19:47:9634] TRAINERSOFTWARE:  [CPU] Name: Intel(R) Core(TM) i7-4710HQ CPU @ 2.50GHz; Cores: 4; Logical Processors: 8
[INFO  2017.02.15 16:19:47:9790] TRAINERSOFTWARE:  [MEM] Capacity: 8 589 934 592; Speed: 1600
[INFO  2017.02.15 16:19:48:0103] TRAINERSOFTWARE:  [SND] Caption: Realtek High Definition Audio
[INFO  2017.02.15 16:19:48:0103] TRAINERSOFTWARE:  [SND] Caption: NVIDIA Virtual Audio Device (Wave Extensible) (WDM)
[INFO  2017.02.15 16:19:48:0572] TRAINERSOFTWARE:  [GPU] Caption: Intel(R) HD Graphics 4600; RAM: 2 181 038 080; Version: 10.18.10.3540; Mode: 1920 x 1080 x 4294967296 Farben
[INFO  2017.02.15 16:19:48:0572] TRAINERSOFTWARE:  [GPU] Caption: NVIDIA GeForce GTX 860M; RAM: 4 293 918 720; Version: 10.18.13.5435; Mode:
[INFO  2017.02.15 16:19:48:0572] TRAINERSOFTWARE:  [GPU] Monitors: 1
[INFO  2017.02.15 16:19:48:0728] TRAINERSOFTWARE:  [AntiVirusProduct]: Name: Windows Defender
[INFO  2017.02.15 16:19:48:0728] TRAINERSOFTWARE:  [AntiVirusProduct]: GUID: {D68DDC3A-831F-4fae-9E44-DA132C1ACF46}
[INFO  2017.02.15 16:19:48:0728] TRAINERSOFTWARE:  [AntiVirusProduct]: Path to Product: %ProgramFiles%\Windows Defender\MSASCui.exe
[INFO  2017.02.15 16:19:48:0728] TRAINERSOFTWARE:  [AntiVirusProduct]: Path to Reporting: %ProgramFiles%\Windows Defender\MSASCui.exe
[INFO  2017.02.15 16:19:48:0728] TRAINERSOFTWARE:  [AntiVirusProduct]: Is Enabled: True
[INFO  2017.02.15 16:19:48:0728] TRAINERSOFTWARE:  [AntiSpywareProduct]: Name: Windows Defender
[INFO  2017.02.15 16:19:48:0728] TRAINERSOFTWARE:  [AntiSpywareProduct]: GUID: {D68DDC3A-831F-4fae-9E44-DA132C1ACF46}
[INFO  2017.02.15 16:19:48:0728] TRAINERSOFTWARE:  [AntiSpywareProduct]: Path to Product: %ProgramFiles%\Windows Defender\MSASCui.exe
[INFO  2017.02.15 16:19:48:0728] TRAINERSOFTWARE:  [AntiSpywareProduct]: Path to Reporting: %ProgramFiles%\Windows Defender\MSASCui.exe
[INFO  2017.02.15 16:19:48:0728] TRAINERSOFTWARE:  [AntiSpywareProduct]: Is Enabled: True
[INFO  2017.02.15 16:19:48:0728] TRAINERSOFTWARE:  [FirewallProduct]: None
[INFO  2017.02.15 16:19:49:0151] LOCALIZATION:  Added culture: Deutsch (Deutschland) [de-DE]
[INFO  2017.02.15 16:19:49:0151] LOCALIZATION:  Added culture: Spanisch (Spanien) [es-ES]
[INFO  2017.02.15 16:19:49:0151] LOCALIZATION:  Added culture: Französisch (Frankreich) [fr-FR]
[INFO  2017.02.15 16:19:49:0151] LOCALIZATION:  Added culture: Italienisch (Italien) [it-IT]
[INFO  2017.02.15 16:19:49:0151] LOCALIZATION:  Added culture: Japanisch (Japan) [ja-JP]
[INFO  2017.02.15 16:19:49:0307] LOCALIZATION:  Added culture: Koreanisch (Korea) [ko-KR]
[INFO  2017.02.15 16:19:49:0307] LOCALIZATION:  Added culture: Niederländisch (Niederlande) [nl-NL]
[INFO  2017.02.15 16:19:49:0307] LOCALIZATION:  Added culture: Russisch (Russische Föderation) [ru-RU]
[INFO  2017.02.15 16:19:49:0307] LOCALIZATION:  Added culture: Chinesisch (Vereinfacht, VR China) [zh-CN]
[INFO  2017.02.15 16:19:49:0307] LOCALIZATION:  Added culture: Englisch (USA) [en-US]
[INFO  2017.02.15 16:19:49:4838] TRAINERSOFTWARE:  Opening splash screen.
[INFO  2017.02.15 16:19:54:3269] APPLICATIONLOOP:  Starting update loop: Main loop
[INFO  2017.02.15 16:19:54:3279] APPLICATIONLOOP:  Starting update loop: WebLink loop
[INFO  2017.02.15 16:19:54:7554] PLAYERSERVICE:  Changed current player to: Anonymer Benutzer
[INFO  2017.02.15 16:19:54:7604] SETTINGS:  Loaded culture: en-US
[INFO  2017.02.15 16:19:55:2070] STARTUP:  Setting up userdata folders.
[INFO  2017.02.15 16:19:55:8090] STARTUP:  Migrating video files.
[INFO  2017.02.15 16:19:55:8430] NETWORKAWARENESSSERVICE:  An internet connection is available
[INFO  2017.02.15 16:19:56:4088] STARTUP:  Applying software updates.
[INFO  2017.02.15 16:19:57:0092] STARTUP:  Setting up training data.
[INFO  2017.02.15 16:19:57:4204] INDEXER:  Added new found TTS file to index: C:\ProgramData\Tacx\TrainerSoftware\TTS4\Settings\settings.tts
[INFO  2017.02.15 16:19:57:4532] INDEXER:  Added new found TTS file to index: C:\ProgramData\Tacx\TrainerSoftware\TTS4\Trainings\RLT\Runs\FR-Genos-Rundkurs_Andi_7.tts
[INFO  2017.02.15 16:19:57:4973] TTSDATASERVICE:  Benchmark Caching training data difference: 486,7602ms total: 00:00:00:486
[INFO  2017.02.15 16:19:57:5043] TTSDATASERVICE:  Total trainings folder size: 61689872 bytes.
[INFO  2017.02.15 16:19:57:6097] STARTUP:  Player synchronization started.
[INFO  2017.02.15 16:19:58:0252] STARTUP:  Player synchronization completed.
[INFO  2017.02.15 16:19:58:7089] SETTINGS:  Loaded culture: en-US
[INFO  2017.02.15 16:19:58:8281] SECURITYWIZARD:  LicenseWelcomeViewModel.Activate
[INFO  2017.02.15 16:19:58:8311] SECURITYWIZARD:  LicenseWelcomeViewModel.Activate
[INFO  2017.02.15 16:20:02:0830] TRAINERSOFTWARE:  Opening main window.
[INFO  2017.02.15 16:20:03:8650] PLAYERSERVICE:  Changed current player to: Andi
[INFO  2017.02.15 16:20:03:8661] SETTINGS:  Loaded culture: en-US
[INFO  2017.02.15 16:20:03:8801] WIRELESS:  WirelessBrakeController is initialized.
[INFO  2017.02.15 16:20:03:8841] NEWS:  Starting news retrieval.
[INFO  2017.02.15 16:20:03:9462] WEBLINKSERVICE:  Connecting to the main web proxy server...
[WARN  2017.02.15 16:20:04:1421] NEWS:  The response status isNotModified
[INFO  2017.02.15 16:20:04:4275] WEBLINKSERVICE:  Client connected! Authenticating ... (Session ID: 84c13b7f3ccf4beeb661979e42576f1400000000000000000365)
[INFO  2017.02.15 16:20:04:5306] WEBLINKSERVICE:  Client authenticated! (ID: 142955)
[INFO  2017.02.15 16:20:07:4117] TRAININGSERVICE:  CurrentTrainingProgram changed to Anninger-Test-neu
[INFO  2017.02.15 16:20:07:4147] CONTROLCENTRE:  LoadLayout: SelectRLT
[INFO  2017.02.15 16:20:12:0002] APPLICATION:  Setting up cache file: C:\ProgramData\Tacx\TrainerSoftware\TTS4\Cache\fu_cursorcontrol\en-US_data.cache
[INFO  2017.02.15 16:20:15:0269] TRAININGSERVICE:  CurrentTrainingProgram changed to FR-Corsica
[INFO  2017.02.15 16:20:18:5255] TRAININGSERVICE:  Customized startpoint course changed to FR-Corsica(Custom start point)
[INFO  2017.02.15 16:20:18:5315] CONTROLCENTRE:  LoadLayout: SwitchStartPoint
[INFO  2017.02.15 16:20:23:0913] TRAININGSERVICE:  Customized startpoint course changed to FR-Corsica(Custom start point)
[INFO  2017.02.15 16:20:25:2234] TRAININGSERVICE:  Customized startpoint course changed to null
[INFO  2017.02.15 16:20:25:2434] TRAININGSERVICE:  CurrentCourse changed to FR-Corsica(Custom start point)
[INFO  2017.02.15 16:20:25:4336] RUNSERVICE:  Selected program: FR-Corsica
[INFO  2017.02.15 16:20:25:4336] RUNSERVICE:  Selected course: FR-Corsica(Custom start point)
[INFO  2017.02.15 16:20:25:5210] VIDEO:  Advanced Video Player is used in Training Centre.
[INFO  2017.02.15 16:20:25:6110] GOOGLE:  tcp listener started
[INFO  2017.02.15 16:20:26:9311] GOOGLE:  tcp listener started
[INFO  2017.02.15 16:20:27:4604] TRAININGCENTRE:  LoadLayout: DualGoogle
[INFO  2017.02.15 16:20:47:3612] TRAININGCENTRE:  LoadLayout: DualStreetView
[INFO  2017.02.15 16:21:03:1458] TRAININGCENTRE:  LoadLayout: DualGoogle
[ERROR 2017.02.15 16:22:56:1623] GOOGLE:  uncaught exception: [Exception... "Component returned failure code: 0x80040111 (NS_ERROR_NOT_AVAILABLE) [nsIDOMCanvasRenderingContext2D.drawImage]"  nsresult: "0x80040111 (NS_ERROR_NOT_AVAILABLE)"  location: "JS frame :: http://maps.googleapis.com/maps-api-v3/api/js/26/17/imagery_viewer.js :: anonymous :: line 120"  data: no] in  at line 0
[ERROR 2017.02.15 16:22:56:7427] GOOGLE:  uncaught exception: [Exception... "Component returned failure code: 0x80040111 (NS_ERROR_NOT_AVAILABLE) [nsIDOMCanvasRenderingContext2D.drawImage]"  nsresult: "0x80040111 (NS_ERROR_NOT_AVAILABLE)"  location: "JS frame :: http://maps.googleapis.com/maps-api-v3/api/js/26/17/imagery_viewer.js :: anonymous :: line 120"  data: no] in  at line 0
[ERROR 2017.02.15 16:22:57:3882] GOOGLE:  uncaught exception: [Exception... "Component returned failure code: 0x80040111 (NS_ERROR_NOT_AVAILABLE) [nsIDOMCanvasRenderingContext2D.drawImage]"  nsresult: "0x80040111 (NS_ERROR_NOT_AVAILABLE)"  location: "JS frame :: http://maps.googleapis.com/maps-api-v3/api/js/26/17/imagery_viewer.js :: anonymous :: line 120"  data: no] in  at line 0
[ERROR 2017.02.15 16:22:58:2809] GOOGLE:  uncaught exception: [Exception... "Component returned failure code: 0x80040111 (NS_ERROR_NOT_AVAILABLE) [nsIDOMCanvasRenderingContext2D.drawImage]"  nsresult: "0x80040111 (NS_ERROR_NOT_AVAILABLE)"  location: "JS frame :: http://maps.googleapis.com/maps-api-v3/api/js/26/17/imagery_viewer.js :: anonymous :: line 120"  data: no] in  at line 0
[ERROR 2017.02.15 16:23:01:7545] GOOGLE:  uncaught exception: [Exception... "Component returned failure code: 0x80040111 (NS_ERROR_NOT_AVAILABLE) [nsIDOMCanvasRenderingContext2D.drawImage]"  nsresult: "0x80040111 (NS_ERROR_NOT_AVAILABLE)"  location: "JS frame :: http://maps.googleapis.com/maps-api-v3/api/js/26/17/imagery_viewer.js :: anonymous :: line 120"  data: no] in  at line 0
[ERROR 2017.02.15 16:23:02:9697] GOOGLE:  uncaught exception: [Exception... "Component returned failure code: 0x80040111 (NS_ERROR_NOT_AVAILABLE) [nsIDOMCanvasRenderingContext2D.drawImage]"  nsresult: "0x80040111 (NS_ERROR_NOT_AVAILABLE)"  location: "JS frame :: http://maps.googleapis.com/maps-api-v3/api/js/26/17/imagery_viewer.js :: anonymous :: line 120"  data: no] in  at line 0
[ERROR 2017.02.15 16:23:03:8825] GOOGLE:  uncaught exception: [Exception... "Component returned failure code: 0x80040111 (NS_ERROR_NOT_AVAILABLE) [nsIDOMCanvasRenderingContext2D.drawImage]"  nsresult: "0x80040111 (NS_ERROR_NOT_AVAILABLE)"  location: "JS frame :: http://maps.googleapis.com/maps-api-v3/api/js/26/17/imagery_viewer.js :: anonymous :: line 120"  data: no] in  at line 0
Post by Alex Masalovich » Wed Feb 15, 2017 7:11 pm
Old version.
[ERROR 2017.02.15 16:22:56:1623] GOOGLE: uncaught exception: [Exception... "Component returned failure code: 0x80040111 (NS_ERROR_NOT_AVAILABLE) [nsIDOMCanvasRenderingContext2D.drawImage]" nsresult: "0x80040111 (NS_ERROR_NOT_AVAILABLE)" location: "JS frame :: http://maps.googleapis.com/maps-api-v3/ ... _viewer.js :: anonymous :: line 120" data: no] in at line 0
It just says that the image does not have time to load.
mcinner
Post by mcinner » Wed Feb 15, 2017 8:00 pm
...and what can I do?
(apart from update to the latest version...)
Thanx!
Post by Alex Masalovich » Wed Feb 15, 2017 9:36 pm
Perhaps the cache has reached size limit. The cache is somewhere in here:
C:\Users\UserName\AppData\LocalLow\Google\GoogleEarth
It would be nice at the same time to clean the whole system:
http://www.piriform.com/Ccleaner
mcinner
Post by mcinner » Wed Feb 15, 2017 10:22 pm
Thanks - I will look to find the cache directory...
Is Ccleaner (free version) ok?
(and reliable?)
Post by Alex Masalovich » Wed Feb 15, 2017 10:37 pm
(and reliable?)
Yes, the free version is enough. When installing be careful: remove all daws, not to install unnecessary software.
mcinner
Post by mcinner » Wed Feb 15, 2017 10:41 pm
I found a folder:
/user/appdata/LocalLow/Google/GoogleEarth/unified_cache_leveldb_leveldb2.0
with many *.sst files in it (2.074.000.000 bytes in sum)
(But they all have a date - same date - from 2015!)
What shall I do with this files?
Thanks!
Post by Alex Masalovich » Wed Feb 15, 2017 10:54 pm
Delete or move to another location.
mcinner
Post by mcinner » Wed Feb 15, 2017 11:13 pm
Ok, did it - but to no avail.
What do you think about uninstall Google Earth Plugin and reinstall.
(But, by the way - I did not found a download for this Plugin directly from a Google site)
Edit:
Maybe it will help if I install Google Earth desktop version on my laptop. I dont have it yet installed...
Post by Alex Masalovich » Thu Feb 16, 2017 11:27 am
I don't know, maybe that will help a full reinstall of everything connected with the TTS4.
mcinner
Post by mcinner » Thu Feb 16, 2017 11:44 am
Thanx so far for helping.
I just sent a email to Tacx-support with a video - showing the problem.
Now I will wait if there will come a response...
drewtoncrane
Post by drewtoncrane » Thu Feb 16, 2017 5:49 pm
Hi Guys
I am suffering the same issue
Black Screen > then a blurred street view > then a clear picture in street view
Glad it's not just me
Regards
drewtoncrane
Post by drewtoncrane » Thu Feb 16, 2017 5:55 pm
I have received a response from the Help Desk which states
This problem could be related to cache memory
Can you please do the following
Close the software
Start the Tacx Support Tool
Then select RESET GOOGLE CACHE
then try again (close support tool, start the Tacx Trainer software)
If that does not work run the Support Tool
USe REPORT PROBLEM TAB and fill in the data
Tacx will receive log files so we can anayze this
I'll try it when I get home this evening
Post by Alex Masalovich » Thu Feb 16, 2017 6:03 pm
Perhaps this is exactly what we're trying to do it manually.
ttelmah
Post by ttelmah » Thu Feb 16, 2017 6:05 pm
and me.
Sent a mail to Tacx support, before seeing this.
There is a .net framework error generated in the Windows 'application' event log. Nothing in the Tacx logs at all. So it looks as if perhaps the latest Windows update may have changed something. If I've selected the three view screen, it crashes the application completely...
I wasn't sure it was me, since I'd had major problems re-licensing the Google.
Tried to re-license on the 21st Jan, and it took over two weeks before eventually Tacx got this to license correctly. Unfortunately it shows the date when I first tried to license, so I have lost two weeks of my license. Then didn't use it for a couple of days, and when I did started having this problem..
As an interesting 'aside', has anyone else tried the new Google Earth release?. That Google have released a new version of 'Earth', suggests they may be having second thoughts about this. Perhaps Tacx ought to talk to them about whether we could have Google Earth back again (to the poster above, talking about the GE plug-in, the Tacx application has not used GE for quite a while, since Google insisted they were shutting this down, and instead required Tacx to shift to using the Google Maps API). The new Earth, allows you to use the cursor keys and drive 'along' roads, and includes a 3D visualisation as well. The StreetView along roads, gives a much smoother behaviour than maps manages.
I had already used the Tacx tool to clear the cache.
Post by Alex Masalovich » Thu Feb 16, 2017 6:31 pm
And updates for Windows this month just has not been released:
http://www.computerworld.com/article/31 ... delay.html
It's a strange coincidence.
Locked
Return to “FAQ - Tacx Trainer Software 4”
