Importing Garmin traces for training
Here you can discuss the Tacx Cycling App for iOS devices.
jodrell
Post by jodrell » Tue Jan 13, 2015 5:22 pm
Hey guys, I've just brought the Vortex Smart and was told when I did that I'd be able to load courses in from my rides using my Garmin but can't find any information on how to do it. Could someone point me in the right direction please?
Re: Importing Garmin traces for training
Post by malfukt » Tue Jan 13, 2015 8:36 pm
Directly from Garmin Device, just copy the files from device onto PC, then in TTS go to Export/Import tab along top of screen and choose format that files from garmin are..usually "fit"device to "GarminConnect" go to the uploaded ride in "Connect"....above the map of ride is an "EXPORT" tab, you can choose .tcx or .gpx then in TTS Import tab, dropdown menu, give option to import either..
Most users find it best to smooth the ride beforehand as some of the changes in elevation can be a little sharp..
To smooth the elevation of the file use smoothing program available here : http://www.lunicus.org/tacx/GPXsmoother.htm
Post by malfukt » Tue Jan 13, 2015 8:39 pm
NOTE: if you have GARMIN CONNECT on your PC, make sure it is off (exit) when you wish to connect brake/headunit/hr monitor etc... GarminConnect interferes with the connection between TTS antenna and devices
jodrell
Post by jodrell » Wed Jan 14, 2015 10:55 am
Thanks for the info but I'm running the Tacx software on my iPad currently...and my only other option is a Mac. Would I have to connect my MacBook to the Tacx via Bluetooth and control it from that in order to use the Garmin courses or can they be loaded into the the list of workouts on the iPad app?
Post by malfukt » Wed Jan 14, 2015 4:56 pm
Not with the App...importing rides not implemented at present...you can 'create' courses in the dropdown menu on lefthand side of the screen..
Return to “iOS”
