Fortius watts lower than in real life (standard scale factor
gabri
Post by gabri » Tue Dec 23, 2008 11:13 am
Hi I read here and see that most people say the scale factor must be set higher than the 100% standard scalefactor.
However with the standard settings compared to real life watts I'm going slower already.
For example: mont ventoux on the fortius 1hr40 in real life 1hr29, so with the standard scale factor I'm slower already, with a higher scale factor the time would be worse right ?
My player profile is filled in with the right weight and 8kg for the bike.
So I don't think it's really lighter .. but in my case harder than should be ? not a problem though :twisted:
Re: Fortius watts lower than in real life (standard scale fa
Post by mcorn » Tue Dec 23, 2008 3:49 pm
gabri wrote:Hi I read here and see that most people say the scale factor must be set higher than the 100% standard scalefactor.
Yes, a higher scale factor reduces the calculated wattage and makes it harder. The other thing that makes it harder besides entering higher weight is a calibration value that is lower than it should be. So, if you have a calibration of 0 and it should be 2.0, it will be harder. What calibration do you have?
You really need a power meter to use the Scale Factor, but if you think it is too hard, you can set the Scale Factor to less than 100.
principiante
Post by principiante » Thu Feb 05, 2009 5:04 pm
Would you excuse my question. Where can i change the scale factor?
Post by mcorn » Thu Feb 05, 2009 6:55 pm
principiante wrote:Would you excuse my question. Where can i change the scale factor?
In the systems options, there is a Scale Factor setting. It is also described in the manual.
