Power accuracy without cadence sensor
Xcyrus
Post by Xcyrus » Wed May 27, 2015 10:20 am
Hello,
I have a Flow and I want to know if the power accuracy showed on display will be affected if I remove the cadence sensor.
Re: Power accuracy without cadence sensor
Post by ms6073 » Wed May 27, 2015 3:37 pm
From answers to similar posts, I think the iFlow, like the Fortius and iMagic require the wired cadence to be used as it is sort of safety 'switch' and if no cadence is detected after a few seconds, the motorbrake stops.
Xcyrus
Post by Xcyrus » Thu May 28, 2015 10:19 am
Thanks for answer but I have Flow not iFlow.
The motorbrake isn't affected at all if I did not mount the cadence sensor ( which is dead anyway ).
The question is about the readings on the display...if it will affect the power readings on the display.
EHB
Post by EHB » Fri Mar 11, 2016 11:59 am
I used to have a Flow (T2200 I think) and had a Power2Max power meter. The cadence sensor is not needed for power. One thing I did notice is that the reproducibility is very effected by tyre pressure and screw tightness even if you recalibrate every day. It is possible to get it consistent and within 10W of a PM, but you have to be really strict with keeping everything the same. Also it isn't quick to react to changes in power, so don't be disappointed by sprint power as the actual power will be much higher.
