Satori T2400 Calibration issue - power way too hugh
bikergroves
Post by bikergroves » Fri Jan 15, 2016 1:14 pm
I have recently purchased a new Tacx Sator 2400 from Evans Cycles, in the UK.
The hardware ( the actual turbo) is pretty good however its seriously let down by the app and connectivity ( or lack of) with the PC.
I am trying to calibrate the device however its power reading is far too high on the app and my Garmin 800.
Simply put, when I try to calibrate it I follow all the instructions, put the handlebar tension at 1 and cycle to 40kph.
Unfortunately, its telling me the tension is TOO LOOSE however I have tightened it as hard as possible and I can see the magnetic roller is pushed will into the Tyre.
Any suggestions?
millsy83
Re: Satori T2400 Calibration issue - power way too hugh
Post by millsy83 » Wed Feb 10, 2016 12:21 am
Same problem here, not impressed so far. Anyone have any ideas?
sebu
Post by sebu » Wed Mar 02, 2016 10:25 am
I have the same issue.
I have tightend the tightener so hard that the screw felt out of the thread. So its not possible to get the tire closer to the magnetic roller??
ralph014
Post by ralph014 » Sun Jun 05, 2016 11:42 am
Did anyone work this out? I set mine up last night and same problems.
Cheers
